![]() | Home > Technical (L322) > access to dealer programming equipment |
I believe AutoLogic can do this for you. You're much more likely to find an indy that has AL rather than T4.
Rob2529 Member Since: 22 Nov 2010 Location: Wirral, uk Posts: 1470 ![]() ![]() ![]() |
Matt
Jonno Member Since: 08 Jun 2011 Location: Eastnor HR8 Posts: 191 ![]() ![]() ![]() |
Matt
nbunney Member Since: 10 Aug 2008 Location: Lancashire Posts: 2075 ![]() ![]() ![]() |
simon1233 Member Since: 13 Jun 2011 Location: Leyland, sometimes Darmstadt Posts: 650 ![]() ![]() |
Could also try K motors in Leyland |
K Motors |
Nigel, really, you don't like K motors?
Simon
Thanks for the info Nigel, will give independent Landrover services a whirl when I next need a service, won't be needing them for issues for the next 2 years as the vogue I just bought has 2 years Landrover warranty. |
GregP Member Since: 11 Dec 2010 Location: Exmouth Posts: 1084 ![]() ![]() ![]() |
My bro has the Autologic tool at his garage. Only trouble is I'm miles away from you.
mattstevenson2005 Member Since: 01 Jan 2011 Location: Manchester, UK Posts: 737 ![]() ![]() ![]() |
hi guys
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3958 ![]() ![]() ![]() |
Being a lancashire lad I will have to choose somewhere for my next service and any warranty work that might need doing (Warranty Direct). I can see there is at least one very strong negative view on the forum about K Motors with a corresponding strong positive one for ILRS Preston. When I had a problem with suspension height settings none of the independants I spoke to filled me with confidence, including these two, and Windmill Nr. Blackburn (who sold me the car) so I took it to the main dealer in Brock (now Hunters) and although it actually was a straighforward and efficient experince it was expensive.
For routine servicing, I don't have any issue with K motors, they were efficient, helpful and their work did not invalidate my approved used Landrover warranty. The day before I traded my sport for the full fat they diagnosed a fault for me at no cost (especially as the part that was faulty was under a Landrover parts warranty having been replaced by the dealer at Brock 6 months earlier |
Up to you, but I would only go to Indi in Preston. |
