Home > Technical (L322) > ZF8 oil and filter change
rainifa
Hi all. Just changed filter pan and oil, all without issue and used GAP iid to check temperature etc. car was on ramps and pretty level. However, 4 litres of oil came out, but slightly less than 3 went back in. I cycled through the gears etc as instructed. Any one have a clue as to what’s going on? Don’t think it was overfilled as I understand oil drains from an overflow at running temperatures. Went for a short trip on completion and seems to work ok. Thanks. Chris
Post #709730 20th Jan 2025 3:38pm
RRPhil
Did you have the engine ticking over while you checked the fluid level?
Phil
Post #709734 20th Jan 2025 3:57pm
rainifa
Hi Phil. No, I turned it off after I’d got it up to temp and then removed the fill plug. I got another half litre in at that point, but total less than 3 litres. Do you think that would make much difference, i.e. another litre? Thanks
Post #709737 20th Jan 2025 4:44pm
rainifa
I think you’re right Phil. I’ve re-read the instructions and missed the bit where it says keep the engine running! Thanks for your suggestion-spot on.
Post #709740 20th Jan 2025 5:10pm
RRPhil
The reason it’s important is because, the moment you turn the engine off, the transmission oil pump stops and the torque converter starts to drain down into the sump. This produces an artificially high fluid level, preventing you from putting in the correct amount of fluid before it overflows from the filler hole.
Phil
Post #709757 20th Jan 2025 7:11pm
rainifa
Yep, makes complete sense. Loads more jobs to do so I’m sure I’ll be back😂
Post #709758 20th Jan 2025 7:16pm
DrRob
Full Fat 4x4 has just done a YouTube video on this
?si=6aBD_H1kTwo5zDvG Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
Post #709767 20th Jan 2025 9:11pm
ajac8
United Kingdom 2013 Range Rover Autobiography SDV8 Baltic Blue
Is this the same gearbox in a 2013 4.4 405? 405 AB exec seats Baltic and Cirrus
93 RR Classic efi
Remember it's easier to get forgiveness than permission!
Gone in order:
4.4 TDV8 SE - gone to a good home
93 Classic hard dash Plymouth Blue
03 L322 Oslo Blue
2000 Disco TD5 ES Epsom Green
98 P38 Rioja Red
89 Classic Cairngorm Brown
Post #709832 21st Jan 2025 8:36pm
RRPhil
Yep - ZF 8HP70
Phil
Post #709920 22nd Jan 2025 8:45pm
