Home > Technical (L322) > Gas discharge 30 seconds after parking
hedges12
United Kingdom 2011 Range Rover Autobiography 5.0 SC V8 Galway Green
Chaps
Shortly after parking I get a single discharge of air from what I think is near the nearside back wheel.
Very disconcerting as I think the airbag is dying but everything in terms of ride height etc seems absolutely fine.
Is this a known thing/ any idea would be extremely welcome/ fixes.
Post #709754 20th Jan 2025 6:43pm
fisha
If I remember correctly the suspension draws air in and vents air out through an air dryer filter thing … which is all in the compressor unit under the boot floor.. when it parks up it normally does a quick level by letting down the sides to get level , this venting the air. … so is that where you are hearing it from? V8 or else ...
Post #709759 20th Jan 2025 7:27pm
mjdronfield
The above mentioned compressor is inside under the boot floor… in the spare wheel well under the wheel.
There is also an air tank outside under the sill under the rear passenger door… could be that.
It releases some pressure when you lock the car/turn ignition off if I remember right.
You prob need to rule those out first.
I don’t ear anything from the compressor on mine though, but sometimes there is an air release from near the air tank area.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #709760 20th Jan 2025 7:39pm
Rambles
2011 Range Rover Vogue SE TDV8 Stornoway Grey
Mine does it every time
When i stop, i full car into access height
And about 15 seconds after i have shut engine off and turned off ignition, the air suspension lets some air go from the rear
Of note…i park on slope. So car is levelling itself even when parked
No problems with suspension when car is running
Post #709768 20th Jan 2025 9:11pm
