Home > Technical (L405) > Auxiliary reverse light.
dave the builder
United Kingdom 2013 Range Rover Autobiography SDV8 Causeway Grey
Hi, I need to fit an extra reverse light om my FFRR 2013 L405 as what i have now are useless, anyone help with which wires to slice to in existing rear light so it comes on when existing reverse light does. Any help greatly appreciated. Dave
Post #709825 21st Jan 2025 7:32pm
From the Workshop manual available for free download in the WIKI....
Looks like left rear lamp reversing signal is grey with a brown tracer and the right lamp is grey with violet tracer....
 Pete
Post #709845 21st Jan 2025 9:24pm
dave the builder
Many thanks.
Post #709850 21st Jan 2025 9:40pm
You in theory have a reverse light cable behind the rear bumper on the towing connectors where you would plug in the towing electric kit. There is nothing that can't be fixed with a hammer😜😜
Post #709853 21st Jan 2025 10:18pm
dave the builder
Hi thanks, I have the pull off panel, which is where I plan on putting the light but don't have a towbar. I haven't looked as yet but are you saying the wiring would be there incase I wanted a towbar ? If so what colour would I use ? Cheers
Post #709857 21st Jan 2025 10:32pm
Yes the wiring should be there clipped up behind the crash bar.
In terms of wire colour that’s more tricky. Might be a case of testing which goes live when you engage reverse. There is nothing that can't be fixed with a hammer😜😜
Post #709915 22nd Jan 2025 7:07pm
Gremlin500
@OP,
Have you read this thread?
https://www.fullfatrr.com/forum/topic68783...ler+socket V6 Vogue - “Less is More” - less to go wrong!
Post #709916 22nd Jan 2025 8:30pm
dave the builder
Thanks. Looked inside today and there is two connectors which I assume are for the towbar harness. As you say will look to see which was works when reverse is engaged.
Post #709925 22nd Jan 2025 9:37pm
IGP
United Kingdom 2013 Range Rover Vogue SE SDV8 Siberian Silver
On the 13 pin reverse is pin 8 (pink) and ground is pin 3 (white)
HTH
Ivan 2013 Vogue SE SDV8
2013 Freelander 2 SD4 HSE Luxury
Post #709977 23rd Jan 2025 3:52pm
dave the builder
Thanks
Post #709978 23rd Jan 2025 3:54pm
JST
England 2012 Range Rover Westminster 4.4 V8 Stornoway Grey
You have tried upgrading the standard bulbs? Cheers
James
Post #710027 24th Jan 2025 12:38am
JST
James
Post #710028 24th Jan 2025 12:39am
Just had a look. Thought I might have the old towing wiring I just swapped out as the socket was broken. But it looks like I chucked it out.
Reverse is only on the 13 pin or 12S sockets. So if you are looking to pick up some connectors have a look on the bay for those. There is nothing that can't be fixed with a hammer😜😜
Post #710030 24th Jan 2025 8:24am
