![]() | Home > Maintenance & Mods (L405) > Low SAPS 5W40 synth engine oil |
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1778 ![]() ![]() ![]() |
Well, yes, we can choose to ignore the legislation and the environment, of course, each to his own. |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3925 ![]() ![]() ![]() |
I got to wondering did JLR and Ford choose 5W-30 C1 because it was easily obtained OR did 5W-30 C1 become readily available BECAUSE JLR and Ford recommended it. |
@Geoff:
Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 ![]() ![]() ![]() |
Some more content about problems with oil, and emissions, not just JLR.
roel2018 Member Since: 01 Oct 2018 Location: Groningen Posts: 41 ![]() ![]() ![]() |
I'd like to make it concrete: for a 2017 SDV8 with DPF and Adblue the 5W40 C4 is the best oil?
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 537 ![]() ![]() |
Just to be clear, it's my understanding that 5W/40 C1 or 5W/40 C4 is not currently obtainable - in the UK at least, or Europe it would seem!
Hi Jon, very well put, I thought.
Thats true. The Queen from LR Time is a non Adblue SDV8 EURO5 diesel. So they I have nothing to do with Adblue. In this discussion it is not very clear which oil I have to use for a 2017 SDV8 EURO 6 Adblue.
Thanks Gremlin, appreciate that! ![]() 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Hi roel2018,
Without checking the spec sheets for the first two oils, I don't know the difference between them. I would point out that they are both C3 oils (mid SAPS) and not C1 oils. BUT, the Shell Helix you refer to is not suitable for a DPF equipped vehicle being an A3/B3. I think you know this, but just though I'd point it out! ![]() A quick summary of available oil classifications can be found here: https://penriteoil.com.au/knowledge-centre...ations/364
The message you included isn't from LR, it's from a independent garage with an owners club as far as I can tell from their web site.
But that's the point, there's no availability of 5W/40 C1 right now!! EDITED, did say 'no such thing'.
Can't comment on LR not making a distinction between Euro 5 / 6 TDV8's, the reply you posted was from Range Rover World? Perhaps you're referencing other material? Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Hi Jon, I was about to pen a very similar reply |
Fully agree Gremlin500 |
Oh, it’s available allright, but only in huge quantities! 🙁 V6 Vogue - “Less is More” - less to go wrong! |
M11buc Member Since: 06 May 2019 Location: Newcastle upon Tyne Posts: 44 ![]() ![]() ![]() |
Don’t know if anyone looked into seeing if it’s possible for a 5/40 C1 oil to be formulated by an oil manufacturer the uk ? |
