Home > Maintenance & Mods (L405) > 2019 L405 brake Auto Hold? GAP IID G4
TomekW
Poland 2019 Range Rover Autobiography 5.0 SC V8 Indus Silver
Hi All,
trying to activate Brake Hold (Auto Hold) functionality in 2019 L405 and 2017 L462. My assumption is if ACC with Stop&Go can hold brakes, it should be possible to trigger brake hold by user.
Comparing CCF files from 2021 L663, 2020 L560, 2019 L405 and 2017 L462 I was able to get the menu and submenu in instrument cluster (L405), I can check the options but they are unchecking themselves after 1-2 seconds.
What am I missing? What else shall I do to get the Auto Hold working?
First picture below shows the menu, marked phrase says "Brake Auto Hold"
Second picture shows submenu with options:
- hold on demand
- advanced brake auto hold
thanks for sharing knowledge!
Post #707805 29th Dec 2024 11:31am
Sooty
United Kingdom 2019 Range Rover Autobiography SDV8 Silicon Silver
Hi - Did you ever figure this out? I would subscribe to the same logic in and guess it should be possible!
Post #709862 21st Jan 2025 11:11pm
TomekW
no luck so far but keep trying
Post #709935 23rd Jan 2025 12:13am
Philip
2019 Range Rover Autobiography SDV8 Aintree Green
Think if such a useful option was workable, they’d have done it. It’s annoying getting out of something else with it and remembering it doesn’t work.
Post #709936 23rd Jan 2025 1:10am
Gremlin500
In my experience with other activations on the L405, if items immediately deselect themselves from a menu, then it means there is either a missing hardware module, or an incorrect version hardware module present.
I experienced exactly this when trying to activate TSR on my L405. V6 Vogue - “Less is More” - less to go wrong!
Post #709941 23rd Jan 2025 8:27am
Sooty
FYI, I contacted a company based in the UK called Hunters Prestige. They specialise in retrofitting Landrovers, particularly the L663 Defender and the new L460. Here’s their response to my question:
Quote:
Regarding your inquiry about adding the Brake Hold function to your 2019 Range Rover L405 Autobiography, I'm afraid this is not a simple activation. It requires additional hardware to be retrofitted to the vehicle. Unfortunately, this is not a service we currently offer for this specific model.
It seems I’ll have to keep pulling the parking brake lever while sitting at the lights!
Post #709944 23rd Jan 2025 8:48am
Gremlin500
This EPB behaviour seems to be very model/year/market dependent, so if you read this, don’t assume anything, and refer to the correct information for your country and model year. Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #709987 23rd Jan 2025 5:30pm
