Home > Maintenance & Mods (L405) > Oil Level
supershuttle
Oil Level
Since I had my car serviced I occasionally get a whiff of oil in the car. So I thought they may have overfilled it or maybe spilt some oil on something that gets hot. To eliminate the first I used the oil level indicator from the service menu - it shows full. However my question is if it were overfilled would it just show as full or would it show more, I realise that this could be a difficult question but I suppose I could suck a bit out and see if it still shows full but as I say its only the occasional whiff and its a bit wild out there at the moment Geoff
Post #710052 24th Jan 2025 2:50pm
4RRS
United Kingdom 2016 Range Rover SVAutobiography SDV8 Corris Grey
If they overfilled it, the oil display messaage says 'Overfilled' so I'd say your level is fine. MD's now use an automated machine that fills the oil automatically to the correct amount, asuming of course they select the correct engine!!
Years ago when it was first introduced the MD where my mate works had the machine setup wrongly and cost them several replacement engines Laughing L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division.
Post #710053 24th Jan 2025 3:05pm
Baltic Blue
L322 display, but 405 will be similar.
Mike ๐Ÿ‘ G reg 2.5VM Vogue Portofino red 1991- 1999
Post #710057 24th Jan 2025 3:44pm
ReggieMac
United Kingdom 2019 Range Rover Autobiography SDV8 Loire Blue
Could be coincidental with the service but one of the more common culprits for this smell of oil can be the oil cooler leaking but obviously that depends on the engine, mileage, etc. _______________________________________________
2019 4.4 V8 Diesel Range Rover Autobiography, Byron Blue
Post #710076 24th Jan 2025 6:07pm
Mine 322 got overfilled at the dealer so I had to drop a boy on it. It does say on the dash indicator.
Could be the cooler or the o rings on the turbo feed leaking also. There is nothing that can't be fixed with a hammer๐Ÿ˜œ๐Ÿ˜œ
Post #710108 25th Jan 2025 7:14am
supershuttle
I'll just keep an eye on things, certainly doesn't look overfilled (it fluctuates between this and max) also the oily smell has now gone.
 Geoff
Post #710335 27th Jan 2025 4:19pm
bigdave
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
Sorry to hijack the thread but then picture above has a little green triple on the right hand side.
What does tht indicate?
Thanks and sorry.
Post #710345 27th Jan 2025 5:35pm
FORWARD ALERT
The Forward Alert symbol looks like a vehicle surrounded by a triangle. When this symbol appears green, the Forward Alert feature is active, which means your Land Rover will alert you when you cease to maintain a safe distance from vehicles in front of you.
Post #710346 27th Jan 2025 5:43pm
supershuttle
Alistair is right, my son wont travel with me unless Forward Alert is on, the dash lights up like a Christmas Tree if you get too close and also there is a heck of a noise comes through the speakers. Don't tell my son but it's helped me a few times being the absent minded old fool he thinks I am. Very Happy Geoff
Post #710348 27th Jan 2025 5:53pm
Stuart-
Indeed. Mine needed an oil cooler at 60k miles.
The topic is >here< to see if your symptoms are similar. 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
2006 Bentley Flying Spur in silver
Post #710363 27th Jan 2025 8:29pm
bigdave
Thanks Chaps.
Forward alert - I will look it up.
Dave
Post #710366 27th Jan 2025 8:40pm
