![]() | Home > Technical (L405) > Engine cut off while driving and not only |
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2770
What engine fault codes are stored when it stops? If none then the crankshaft position sensor may be faulty, easily confirmed by logging engine RPM whilst idling with a diagnostic tool which will show momentary 0 or very low rpm. |
| valeriu negara Member Since: 05 Jun 2024 Location: london Posts: 3
Hi , the fault shown is
| GrandadRob Member Since: 01 Jul 2021 Location: North Herefordshire Posts: 242
Have a look at a thread in 2023 started by bikereacer . It's a problem that I had too, with a simple fix. 2013 SDV8 4.4 SE Luxor.
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381
Have you changed the fuel filter…if you have had debris in the tank/pump the filter could be blocked leading to fuel starvation and limited fuel rail pressure. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
yes i did changed it , two times after pumps replacement , and ill change it again just to be sure but before changing it it done the same thing and after that also . |
| Chakalisa Member Since: 26 Jan 2025 Location: London Posts: 4
Did you find a fix to this issue ? |
In my particular case, my problem was solved by the replacement of one simple wire. The problem is that LR decided to use two pieces of wire and join them with a connector, the connector fails. There is a replacement one piece of wire available. There is a LR sheet available. 2013 SDV8 4.4 SE Luxor.
The LR document is LTB01083 Published on 13/7/2017 2013 SDV8 4.4 SE Luxor.
Thank you
This may explain the problem.. LTB01083. 13th July 2017.
This is the exact problem and they peformef the following
yes, never happened again. 2013 SDV8 4.4 SE Luxor.
It happened again and now getting another issue
