Home > eBay & Bargain Spots > 5 ton bottle jack @ £18.39 plus £6.99 delivery
https://www.sgs-engineering.com/bj5s-5-ton...b99588028c
Post #710236 26th Jan 2025 3:05pm
supershuttle
That looks reasonable value, I have noticed that the Mercedes Sprinter jacks have gone up a bit since I bought mine for 15 quid and just gave it away with the car when I sold it. Use a trolley jack now, again I think bought from SGS Geoff
Post #710239 26th Jan 2025 3:54pm
Buellie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Orkney Grey
Would that be tall enough for an L322? Dec 2011 L322 Range Rover Vogue SE TDV8 Orkney Grey/Sand leather
Post #710249 26th Jan 2025 6:49pm
FuriousD
Could see that being useful, thanks,
Post #710281 26th Jan 2025 10:30pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
Just ordered one, thanks for the heads up Thumbs Up
Post #710401 28th Jan 2025 9:20am
Stuart-
Is 413mm enough? Don't the Sprinter ones go to 500+? 2017 4.4 SDV8 Autobiography in black
2018 D300 SE Velar in champagne
1991 Mercedes 420 SEL
Post #710432 28th Jan 2025 3:50pm
Gremlin500
YGWYPF.
This one goes up to 520mm:
https://www.sealey.co.uk/product/563796058...k-10-tonne
Cool V6 Vogue - “Less is More” - less to go wrong!
Post #710433 28th Jan 2025 4:19pm
Gremlin500
Forgot to say, before you buy a jack, check to see if you can get spares.
So many of the cheap jacks you can’t buy any spares, then you have to bin them when they start to leak.
Depends on how much use it gets, I suppose! Whistle V6 Vogue - “Less is More” - less to go wrong!
Post #710436 28th Jan 2025 4:29pm
supershuttle
Look at the 10 ton one from SGS it lifts a bit higher. Geoff
Post #710452 28th Jan 2025 5:53pm
this one Geoff?
Post #710455 28th Jan 2025 6:12pm
supershuttle
Its lifts a bit higher but I don't know how much is needed to get the 322 of the ground Geoff
Post #710470 28th Jan 2025 8:32pm
i've used a block of wood or a brick under the jack to get the height ...all depends on the jacking situation. ... - .- -.
Post #710478 28th Jan 2025 10:20pm
Stuart-
Gremlin500 wrote:
YGWYPF.
Cool
And it's £200. Making a German-made Sprinter one look cheap. 2017 4.4 SDV8 Autobiography in black
Post #710510 29th Jan 2025 12:31pm
