Home > Technical (L322) > I broke cruise with ccf, can't remember how
BiggerBaloo
United Kingdom 2010 Range Rover Autobiography Black TDV8 Santorini Black
Hi all,
I'm not a heavy poster, but have been lingering for quite a while. Most things I've needed have already been covered in this brilliant forum, but I'm struggling to find answers to the following.
My 2011 4.4TDV8 has been broken since before Christmas with a fuel pressure issue. I work away, so have only been tinkering at the weekends. About 3/4 weeks ago, I thought I'd fixed it, then started playing with the CCF in the IID tool. Then realised my car isn't fixed. Today I finally managed to fix the fueling issue, and realised I've broken my cruise control, probably by editing the ccf a few weeks ago. I can't remember what I did, and everything looks right to me. But I am the sort of guy that presses the red button with a warning, to see what it does. I'm getting a warning on the dash to say forward control isn't available and the yellow double arrows are constantly flashing.
I can't find any default settings anywhere, and appreciate every vehicle is slightly different. Is there a resource where I can cross reference my settings against known good settings?
I've got an 8 hour drive to undertake tomorrow, then the same again to get back next week. It would be much nicer with CC working as it should be. Any help appreciated. (Sorry for the long post)
Post #710248 26th Jan 2025 6:44pm
You can revert your CCF to what it was the first time the IID was plugged in...
Check the manual, it says how to do it.... Thumbs Up Pete
-Click here for Thread-
Post #710250 26th Jan 2025 6:55pm
BiggerBaloo
Awesome, thanks 😊
Post #710254 26th Jan 2025 7:33pm
BiggerBaloo
That didn't work. I'm getting an error code relating to an ABS sensor. I figured it may be due to SAS, but I've calibrated that a couple times to no avail.
Seems strange that the date and time stamp is in the future. Three date in the car is currently 01/01/2009. Could this be a clue?
Post #710256 26th Jan 2025 7:57pm
Date discrepancy is built in...!!!
Make sure your battery is fully charged then try clearing the code....
Can't see how reverting your CCF could cause a fault....
Maybe someone knows more.... Pete
Post #710263 26th Jan 2025 8:42pm
BiggerBaloo
When I started the car early hours this morning, I turned the steering to full lock left, held for 3 seconds, full lock right and held, then back to the middle. Less than a mile later, the yellow dash warning disappeared and the cruise control works perfectly.
I don't know where the idea came from, and can only assume it's a manual SAS calibration from the deep recesses, that seemed to work better than trying with the IID (despite the success message).
Post #710301 27th Jan 2025 10:55am
