![]() | Home > Maintenance & Mods (L322) > Gearbox service kit. |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1023 ![]() ![]() |
You need to be sure that you’re getting a genuine IBS Filtran sump/filter as well as ZF Lifeguard Fluid 6.
Crispian22 Member Since: 25 May 2017 Location: Midlands Posts: 144 ![]() ![]() ![]() |
Thanks for your reply Phil, are those parts you mentioned part of the service items required along with the the sump and fluid?
Personally, if the connector sleeve is showing no signs of leakage, and the transmission is behaving itself, I’d be tempted to keep the disturbance to a minimum and to replace just the sump pan and fluid and leave the other components for another day.
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1031 ![]() ![]() |
Iv just bought full service kit for my new to me 5.0 sc. Ebay jobbies all say genuin......iv got transmission shudder which didn't show up on the test drive but on the way home after the deal was done. I'm planning on a full flush 1st with 10 litres of trans fluid then I'm dropping the pan and filter plus the bridges seal and drop tubes. Sorry to hi jack but advice from Phil is worth its weight in gold |
As you’re actually experiencing some issues with your 6HP28 transmission, I think your suggestion to replace the bridge seal and jump tubes, as well as the sump pan and fluid, is very sensible as a first step. You’ll then have to re-evaluate, depending on whether it cures the shudder or not. Hopefully it will. Phil |
Yes I see what you mean.
RogueRanger Member Since: 03 Jan 2024 Location: Kent Posts: 117 ![]() ![]() ![]() |
I bought a refurb kit from a member here a few weeks ago. He bought it from Sussex Autos and it included a Zip Kit and the correct transmission fluid.
Cheers Phil I'm also glad you have the same opinion as me about the sleeve...if it's not leaking leave it alone. |
