![]() | Home > Technical (L405) > 2013 Charging System Fault |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1495 ![]() ![]() |
I think the alternator varies its output depending on what load it thinks it needs to supply, so at idle if its not doing much, then it'll drop its output voltage.
Demerara Member Since: 30 Dec 2024 Location: Alberta Posts: 8 ![]() ![]() ![]() |
Thanks for the reply fisha. I did the load test and with the alternator running the voltage does not drop appreciably with a high electrical load, stays in range of 13.6 to 14.2. Is it suppose to fluctuate between a range or stay steady?
darren3005 Member Since: 01 Nov 2023 Location: Somerset Posts: 66 ![]() ![]() ![]() |
So I had the Charging System Fault about six months ago, turned out to be the alternator. Funny thing is a few day before the message came on I did smell a very electrical smell, if you know what I mean. I thought it was the car ahead but im gussing now it was my alternator giving up the ghost. You've bought WHAT!! |
Update: RR showing to be very temperamental
AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 676 ![]() ![]() ![]() |
I could be the battery monitor itself giving spurious readings.
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8673 ![]() ![]() ![]() |
You probably have some codes stored which your cheap OBD will not read....??
Andy, your suggestion appears to be correct, I replaced the BMS and the warning has so far gone away. I was foolish enough to purchase a new battery and alternator in the meantime however..... |
