Home > Maintenance & Mods (L322) > Another Rear wash wipe
Discofish
England 2003 Range Rover HSE Td6 Oslo Blue
I don't get any water on the rear window when wiping, seeing other posts this should happen so what issues are common? i expect there is a separate pump for the rear somewhere with tubing attached again assuming stuck to the washer bottle
Post #710706 31st Jan 2025 5:58pm
TDV8_Tommy
Spain 2012 Range Rover Westminster TDV8 Baltic Blue
I fixed mine a couple of weeks ago.
The rear pipe, attached to the motor, blew off causing a mini-flood in the boot.
I took the motor out and through a process of elimination it turned out to be a the two nozzle jets were totally blocked. Using a safety pin I cleaned the jets, re-assembled and it all works perfectly again.
I braced for the worse, but it was a quick simple fix. Toys were not thrown 😂 2012 4.4 TDV8 Westminster - Baltic Blue, Jet interior
1997 P38 2.5 DSE auto & 1998 P38 2.5 DT Manual
1988 Vogue 3.5 EFI - Manual, gone.
2004 Volvo C70 2.0T convertible, had since new.
2007 Mazda MX-5 2.0 Sport Roadster/Coupé, had since new.
2024 Mini Cooper S cabrio, JCW kit, 2.0, DCT auto
Post #710723 31st Jan 2025 8:36pm
pcourtney
I must look into mine, since the very cold snap we had I have no water
Has anyone bought these UPDATED VERSION Replacement L322 rear wiper jet nozzle £15 quid off ebay
https://www.ebay.co.uk/itm/255955007977
You will have to remove the Rear spoiler and the plastic nipple from the wiper motor, to be able to install this part correctly. The wiper rest point must be set in the original factory position (see pic)
Comes complete with replacement Carbon filled Nylon nut that has 3 dimples for the grub screw to locate into. This modification means that you just have to nip up the grub screw, thus preventing accidental stripping of the thread in the water jet body.
I have designed this custom water jet nozzle as I couldn’t find a replacement anywhere and didn’t want to spend £85 on a complete wiper arm. It is 3D printed in Nylon on an industrial 3D Printer (as used by F1 Teams) and has two jetting nozzles. It has a grub screw to lock it in position onto the new Carbon filled Nylon nut ** DO NOT OVER TIGHTEN** and is fitted with an ‘O’ ring seal .
Please see photo #2 for installation instructions and please note you will have to remove the plastic nipple from the wiper to fit this part.
Post #710738 31st Jan 2025 11:15pm
AlexTVR
Mine was a blocked/broken one way valve in the hose which is located just before the hose attaches to the motor. Gave my nozzles a clean out too.
Be careful of the plastic tabs on the trim panel you have to remove. 2010 Supercharged
Post #710754 1st Feb 2025 2:02pm
m@ttsFF
United Kingdom 2006 Range Rover Supercharged 4.2 SC V8 Buckingham Blue
Replacement L322 rear wiper jet .
I was tempted after my original nozzle broke on removal , but the park position put me off as I like the way it tucks out of sight under the spoiler. I bought new complete wiper arm. P525
4.2 SC - sold , now bought back
4.4 AdBlu Tractor - Stolen
Post #710755 1st Feb 2025 2:18pm
