![]() | Home > Technical (L322) > Oil cooler and belt 2011 4.4TDV8 |
JMC Member Since: 01 Feb 2009 Location: Aberdeen-Angus Posts: 799 ![]() ![]() ![]() |
Removal of the oil cooler has nothing to do with any of the belt(s). It's always possible they may have spilled something on it though. The older I get, the more I realise that people confuse wrinkles for wisdom |
tigmutt Member Since: 15 Oct 2024 Location: Bolton Posts: 29 ![]() ![]() |
Ok thanks. I’ll replace the belt. |
PeteT80 Member Since: 25 Jan 2020 Location: Preston Posts: 233 ![]() ![]() ![]() |
Check the tensioner and pulleys for any play, if you need to replace those then it’s worth doing alternator and water pump at the same time. Can get expensive very quick but it’ll save stripping it down again. |
