![]() | Home > Technical (L405) > 4.4 instant restricted performance |
| fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1561
Almost impossible to say without codes at this point. V8 or else ... |
| GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2773
MAFs are for the primary and secondary turbos, not bank 1 and 2. Airflow through the secondary turbo will be virtually nil unless the secondary turbo is working. |
| Jimes256 Member Since: 14 Mar 2021 Location: Bath Posts: 45
Last code was p00bf air flow too high. Previous was that and p004d p004b boost control solenoid b circuit high and circuit range performance |
Does it have fitted the additional short loom between the side of the sump and the primary turbo that's meant to stop oil migration along the oil level and temperature sensor harness? |
Not sure I’d have to check |
One thing I did notice was the csov was slow in movement when I put vacuum on and released |
| kevinp Member Since: 28 Sep 2019 Location: Telford Posts: 1364
I know when I tested mine with a vaccum it closed with a good 'thunk'. |
Yeah thought it should. I’ll have to see how quick the gun releases vacuum and just pull pipe to check |
Returning fault is p00bf mass air flow b circuit air flow too high |
P004d-77 and p004b-71 are the codes I can’t get on top off. Anyone had the same? |
For anyone that may encounter the same, turned out the vent to airbox and vacuum supply lines were the wrong way around. Took a while to notice but got there in the end! |
| kevin-t Member Since: 24 Feb 2019 Location: Sheffield Posts: 43
Just a thought!
Excellent! If only all faults were that easy to fix. |
One of my first checks! |
