![]() | Home > Technical (L322) > problem with a TD6 advice needed |
Joe90 Member Since: 29 Apr 2010 Location: Hampshire Posts: 6424 ![]() ![]() |
Have you done a leak test ?
zxrjohn14 Member Since: 01 Feb 2025 Location: Spalding Posts: 19 ![]() ![]() ![]() |
leak off test done and less than 10ml per injector while cranking quite a few times with metering tubes fitted.
double post |
yes injectors... i work a lot on petrol engines and have go to words, i suppose. I'm old and the brain doesn't work like it used to. |
Any codes being thrown up ? .
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 537 ![]() ![]() |
Had a similar issue with my early (2002) 4.4 M62 V8 Petrol L322.
None what so ever. even on a proper LR scanner |
Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8715 ![]() ![]() ![]() |
You don't mention you have changed the fuel filter, I take it you have...??
brand new filter. |
The ineria switch stops the fuel pumping and this one has a healthy flow of fuel |
I have to ask... what's the WIKI?? |
Weegie Member Since: 09 Jun 2014 Location: East Sussex Posts: 3268 ![]() ![]() ![]() |
Top of the screen same box as the two cars shown. Red print WIKI is a forum compendium of information. John
thank you |
bobsin Member Since: 21 May 2015 Location: wolverhampton Posts: 52 ![]() ![]() |
I had similar issue on my otherwise reliable 2004 TD6, just would not start. ran on ezy start, or wd40, 1st time starting. went back to basics. solved it.
