Home > Technical (L405) > L405 steering rack coding
ACW2000
United Kingdom 2014 Range Rover Vogue TDV6 Balmoral Blue
Hi,
Has anyone any experience with replacing a typically failed steering rack on a L405 with a used steering rack from another L405 and solved the coding issue, or know of somewhere in the UK that can assist.
Thanks
Post #687280 5th Mar 2024 5:36pm
V8DHC
United Kingdom 2017 Range Rover Vogue SE SDV8 Orkney Grey
I've got this problem right now.
My coding expert has tried to recode a used motor and module on my old rack and LR have told him:
1. That the module needs to new/wiped before and can't just be recoded
2. That the module and motor is also coded to the rack itself and cannot be treated as a separate component (I don't understand how an electrical component can be 'coded' to a mechanical component but hey ho)
3. LR's solution is to buy a new module at £2.5k + VAT
So I'm going to remove the original rack and sent it together with the original motor/module to be reconditioned for £900 and hope this solves the problem.
Post #711101 5th Feb 2025 1:31pm
Please keep us updated and a link to the company you are using would be good...
Cheers Thumbs Up Pete
-Click here for Thread-
Post #711137 5th Feb 2025 5:40pm
fisha
What went wrong with rack in the first place ? V8 or else ...
Post #711171 5th Feb 2025 10:22pm
Mikey
Seen a few now with snapped bolts holding the motor to the rack...
Post #711179 5th Feb 2025 10:55pm
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
I’m in the same boat ,hoping that Patrick from gap tool will be able to help he did say tho they can be tricky to do
Post #711185 6th Feb 2025 6:53am
V8DHC
The power steering just stopped working - quite an interesting experience when you're haring down the fast lane of a motorway...
At first steering could be reset after restarting the car but this only stopped working after a couple of days. The dash initially indicated a fault but then even the warning messages disappeared.
My local maintenance guy said that the steering module had stopped communicating.
A used replacement motor and module re-established communication but couldn't be coded to the car. I consulted two coding specialists who confirmed that this was the case.
Rack and motor c/w. module now being sent to Western Power Steering in Bristol for reconditioning which includes re-setting the module so that it can be re-coded to the car.
Post #711190 6th Feb 2025 9:55am
fisha
Seems bonkers to lock down a steering rack setup to be car specific. V8 or else ...
Post #711199 6th Feb 2025 10:57am
will308f
This is what mine looks like ….looks l8ke it has been going for a long time before I got the car crazy that this happens
Post #711200 6th Feb 2025 11:34am
fisha
That looks fixable though. The racks unbolt and you can replace the belts.
I managed to extract a sheared bolt from my beemer which has a similar setup and replaced with steel bolts. V8 or else ...
Post #711229 6th Feb 2025 2:52pm
sgorianin@gmail.com
United Kingdom 2015 Range Rover Autobiography 5.0 SC V8 Santorini Black
It is very interesting what JLR is doing to it components. I had no case with rack but I had some issues in the past with different modules. I'm doing it on my own risk and understand that this could be a problem that costs a lot of money after.
But internal mirrors can't be flashing with different software, as well as the parking aid system, as well as the BCM module. All of them locked off and did not respond anymore if you were trying to do something with software.
But what is intriguing is that someone can reset the module. That means that not only them can do it. Some of the guys just don't want to do the things they never done. And as I said it can costs a lot to replace damaged module.
Just let us know if you can sort the things out.
Post #711735 13th Feb 2025 2:43pm
Molloy9999
Post #713012 28th Feb 2025 5:30pm
Molloy9999
Hello, do you have an update on your steering rack.
Post #713013 28th Feb 2025 5:31pm
V8DHC
So Western Power Steering found that they couldn't repair the module on my rack - it was totally unresponsive but offered me a replacement reconditioned rack for an additional £550 which I agreed to.
The new rack arrived 2 working days later and worked perfectly out of the box. Good service (if somewhat poor communications). They seem to know what they're doing and deliver what it says on the can.
Still a hell of a lot cheaper than going to JLR.
FYI, time to remove rack 1hr 15m (on jack stands). Time to replace (with greater care) 2 hrs. (In case you want to price the job at your local supplier - it would be quicker if the car was on a lift).
Post #713149 2nd Mar 2025 10:56am
will308f
Thumbs Up nice to be back on the road again what did you do about getting it coded ?
Post #713153 2nd Mar 2025 11:47am
