![]() | Home > My Range Rover > My new Range Rover… L322 4.4tdv8 Vogue. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
You will be missing some bits if you just remove it. There are a couple of bars which come off when you fit the bar. They would need to go back on.
Ian7430 Member Since: 06 Feb 2025 Location: Oxfordshire Posts: 11 ![]() ![]() ![]() |
Thank you, I was just reaching the same conclusion. A tidy up it is. |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 7964 ![]() ![]() ![]() |
I think you can get a bung to go in the square hole. I even think you can get an aftermarket LED reversing light too…..
Yes stumbled across the bung, got one on order. |
