![]() | Home > Technical (L322) > Forced DPF Regeneration using Gap iid. |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 553 ![]() ![]() |
Is that correct, though? ![]() Surely a Forced DPF regen just starts an Active regen, but when you want one to happen? I don't believe there's any difference in exhaust gas temperatures or stress on the DPF core, etc. In my experience, exhaust gas temps at the various sensors are the same during a Forced regen and an Active one. Additionally, temperatures during a Forced regen do not go beyond those specified in the LR technical literature. This observed in my case with a 3.0 SDV6, but I can't see the TDV8/SDV8 being any different. Reading through the "System Operation and Component Description" for the 4.4 TDV8 L322, there are only 2 types of regens possible, those being the rather ineffective "Passive regen" and the "Active regen" we're discussing here, albeit manually called - or "Forced". At the end of the day, Active regens are automatically performed roughly every 300 miles or so anyway, what's wrong with running one on your terms, when you know it'll have 100% chance to complete? The IID tool, for example, ensures the vehicle is moving and not stationary with the DPF or CAT glowing cherry red! I'm not advocating running them 'willy nilly' all the time. That'll only increase oil dilution, but do it when DPF soot levels are near the trigger point for your vehicle, and you know full well you're about to blast down the motorway for 50 miles. Perhaps also, you know at other times that your driving route comprises many short runs. Two questions then: 1) Am I correct that a Forced regen is *just* an Active regen but run when requested by the user 2) Did I say regen enough times... ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Baltic Blue Member Since: 13 Aug 2015 Location: North Wales Posts: 3880 ![]() ![]() ![]() |
I regularly do the same 23 mile run from Conwy to Llanberis, which is half ( A55 ) at 70mph and half on a 50mph A road.
@ Baltic Blue - Mike, I agree with what you're doing. |
Jon,
