![]() | Home > Technical (L405) > L405 Alarming when Locking |
Matt Buckland Member Since: 27 Nov 2018 Location: Derbyshire Posts: 80 ![]() ![]() ![]() |
I think this is the door latch failing. A common fault and similar to the symptoms I had. The door would not lock with fob - so alarm would sound, mirrors would fold and I’d get the chirps to say “door open”. I used to lock with fob, (alarm sounded), unlock with fob, then re-lock with keyless push on handle on dodgy door in question and that worked until I could get the latch changed.
Paulw Member Since: 29 Nov 2023 Location: Norwich Posts: 5 ![]() ![]() ![]() |
I’ll check the bonnet as I have been under there recently so may be an issue. What’s puzzling me is the reported faulty door is locking perfectly. I understand the latch has a micro switch which tells the car it’s locked so possibly that has failed. |
Yeah, I think it’s the microswitch. On my 2017, the app would alert me and record that the car was unlocked, even though all doors were locked with keyless method. L460 460e PHEV AB. Belgravia green.
So I’ve found a way to repair the latch without removing it.
Top result, well done! Worthy of a celebratory beer. 🍺 L460 460e PHEV AB. Belgravia green.
moe12572 Member Since: 26 Feb 2025 Location: New York, NY Posts: 1 ![]() ![]() ![]() |
I have a 2018 L405, double chirp, and alarm goes off. The alarm indicates its the left door unlocked. I have replaced the actuator and mechanism is working.
