Home > Technical (L322) > Parking sensors not working
RobsterPC
Hey all, my Westie has suddenly decided that the parking sensors are no longer sensing. When I move into reverse, I get a long beep but no more sensor action. I've pulled the codes and the culprit is "B1B50-96 - Rear left inner sensor -Component failure - internal failure (6Cool".
So I suspect my left inner parking sensor has stopped working. Does the hive mind concur? How easy are they to access? If they're easy to get to I can try switching 2 sensors over and see if the code moves. The sensors seem pretty cheap. Any other suggestions?
Post #711681 12th Feb 2025 9:39pm
RobsterPC
A quick update on this, I reset the codes with teh Gap tool and the sensors are now working again as normal. I'm taking that as a win.
Post #712025 17th Feb 2025 11:38am
BAZ8046
This can be water ingress in to the sensor so don't be surprised if it comes up again.
I've had them before when they work if it's been dry but pack up in the wet.
It's also worth checking the wiring to the sensor before diving in and ordering a sensor.
Hope this helps. 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #712028 17th Feb 2025 12:35pm
RobsterPC
Thanks, I'll keep an eye out for it. What's the best way to remove the sensors? I've seen videos which suggest to go from behind the bumper and there's an access hole in the right place. Do they simply push out, i.e. for the rear ones, push them away from the car?
Post #712043 17th Feb 2025 4:00pm
Proftinkerpot
Northern Ireland 2012 Range Rover Westminster TDV8 Stornoway Grey
This is really useful to know as my parking sensors have started doing the same thing just in the past week.
Hopefully a simple fix too.
Post #712068 17th Feb 2025 8:44pm
Range Rover L322
Here is a decent guide we wrote - if it's the module and the problem is occurring when it's rainy.
Good luck.
https://www.fullfatrr.com/forum/topic58516...ing+sensor 2012 L322 4.4 TDV8 AB low mileage - a peach
1986 V8 Defender 90 County ex-Swiss Army - Red everything....
My preferred Independent: Roy Hardy. R & B AUTOS LTD, 20 Brook Road, Wimborne, Dorset, BH21 2BH 07500 866775‬ (Ex LR Chief Technician)
Post #712100 18th Feb 2025 1:30am
