![]() | Home > Technical (L322) > Td6 GM5L40e Gearbox...... |
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1031 ![]() ![]() |
In Manual mode you should be able to select 1st or 2nd gear to set off from stationary (or 1st, 2nd & 3rd in Low Range). Does it make any difference to the engagement delay if you switch to Manual mode and engage 2nd gear, for example?
Pajeroboi Member Since: 18 Oct 2019 Location: Cheltenham Posts: 10 ![]() ![]() |
Thanks for the reply Phil.
Hmmm. Manual 2nd uses the Forward Clutch too, so I think that puts the kibosh on the leaky moulded piston seal theory.
Ahh ok that's interesting and judging by that diagram, it's very blimmin complicated lol
steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 62 ![]() ![]() ![]() |
I can't comment on the drive delay fault but regarding general gear selection and behaviour is that the gearbox will up-shift readily with no load on the gearbox and equally down-shift under very small increases in either load, or very small increases in throttle position. The normal slip speed is around 2,500rpm on my gearbox under modest acceleration, going higher if more pedal is applied.
Hi Phil
Hi Steve, yes it helps massively, thank you. As you can tell by my name, I've come from Pajero's, where this situation is identical. Everyone I've owned (4) has done this. The reason i thought this was unusual on a RR is that my e60, which has the same 3 litre M57 paired with a ZF6 gearbox is as smooth as butter and changes gear exactly when its supposed to and none of this indecisiveness when moving through gears, especially when under load, on a slight incline, where it holds on to 4th (2300-2500 rpm) until you back off the throttle. If i turn the music up and don't look at the rev counter, i don't notice it at all lol, the kids on the other hand aren't massive fans of Motley Crue, Skid Row or any other 80's rock bands, so i cant use that tactic consistantly ![]() |
Glad to give my thoughts! Ive had 3.0 petrol e60 with 6 speed ZF box and completely different as you said.
Ahhh ok, i never even considered that. Thank you Steve, i will add that to the list of jobs....which is growing larger and more expensive by the day lol but the drive is fantastic, so its worth it! L322 2006 |
