![]() | Home > Maintenance & Mods (L322) > Used oil analysis, 4.4TDV8, 25859km. |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1394 ![]() ![]() |
Diesel in the crank starts flashing off at 50 ish degrees, should be all gone pretty rapidly unless continous addition is occurring |
Should have said sump, I suppose really, can't edit on phone though ๐ |
D3Jon Member Since: 15 Aug 2020 Location: Lincolnshire Posts: 537 ![]() ![]() |
If diesel in the sump flashes off at 50ish degrees and should "be all gone pretty rapidly", then why do so many vehicle manufacturers have concerns about oil dilution? Land Rover's own technical note to dealers: http://www.amigo.co.uk/misc/JLRP00100.pdf Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
Because the dpf is regenerating regularly and adding fuel to the sump and the evaporation process can't keep up possibly?
SpitfireS Member Since: 10 Jun 2019 Location: Mainz Posts: 128 ![]() ![]() ![]() |
To D3Jon: if the L322 algorithm concluded it was above critical level already it would have said so.
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1778 ![]() ![]() ![]() |
![]() โIn this test, a sample is heated at 250 ยฐC for 60 minutes with a constant flow of air over it.โ (Quote from your very own link above) You are joking, right? V6 Vogue - โLess is Moreโ - less to go wrong! |
Of course I'm joking ![]() The NOACK test is done to put oils under completely insane conditions, not at all related to actual engine conditions, just to make oils look bad. The Ford Lion 4.4 TDV8 has oil jets too, you know. Oil is sprayed under the hot pistons, it's an oil mist inside the engine.
You know, you (in general) change your oil every 5000km or so, to make you feel good. Fine, go ahead, it's not my money. But don't try to justify it with your semi science or whatever someone told you on a forum without any data to backup their ideas or claims. Just admit: "I do this because I want to and it makes me feel good to work & take care of my car." ![]() 2000 Honda S2000 |
The evaporation point of diesel fuel is between 149 and 371 degrees C according to Wikipediaโฆ Notwithstanding that, any vaporised fuel will condense back to a liquid in the much cooler environment of the crankcase breather system. Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
D3
I'm not sure that the L322 uses oil dilution as a factor in calculating when a service is required. It simply uses time and distance, as far as I'm aware. Anyone know for sure?
It does when you consider the engine utilises sputter bearings. Wear metals will not be evident in an oil analysis until it's too late. GraemeS has discussed in another post on this forum.
Well, yes in your case this is the assumption I've naturally made. As it's the same vehicle with the same driver, presumably using the same driving style and undertaking similar journeys.
I'm not saying there's no evaporation. I don't think I've ever said that. Some diesel fuel remains in the oil though, as your own oil analysis has proven and as evidenced by manufacturer's own concerns - which was the point of linking to JLR's document).
It would be great if you could do an analysis now. That would see if my simple maths is correct and your current fuel dilution is in fact 4.5% ![]() Before anyone suggests I do my own oil analysis's - I don't need to worry about them, I just change my oil every 6k miles or 6 months! I find it to be cheaper and less hassle! ![]() Jon 1992 RR Classic 3.9 efi Vogue 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
That figure comes from a paper discussing marine diesel fuel spillages where the diesel is on the water's surface a few microns thick. This with the action of the wind, sea and sun on it. I'm not saying diesel does not evaporate from the crankcase at all, just that some remains as per the OP's own oil analysis. I posted the document as an example that oil dilution is something that engine manufacturers themselves agree leads to premature wear of engine components. I'm not going to respond any further to your posts on this matter. In fact I can't believe I responded to your Google AI fact above... But it did give me a good laugh ![]() 2014 Disco 4 HSE =================== Both my fatties now gone... Previous: 2011 L322 4.4 TDV8 Vogue SE /// 2002 L322 4.4 V8 HSE /// 2009 Discovery 3 2.7 TDV6 XS /// 2004 Defender 90 TD5 /// 1993 110 V8 Snatch Landrover /// 2005 Discovery 3 2.7 TDV6 SE (Aus) /// 1990 110 Isuzu 3.9 County (Aus) /// 1976 Series III Trayback (Aus) |
As did your Wikipedia post for me
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1401 ![]() ![]() |
We need to take into account that it doesn't naturally vent to atmosphere its a closed system there will be minimal if any natural evaporation.
