|  | Home > Technical (L322) > New 2012 Westminster owner, 3 months in after some advice |
| diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 48      |
|  13th Feb 2025 8:49pm |
| diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 48      | Also, going to collect up bits for full service. But if I keep eye on oil level and coolant is it fine to continue to use it till have everything I need to fix and service as its my daily, thanks | ||
|  13th Feb 2025 8:50pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | Welcome.
|  13th Feb 2025 9:08pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | That’s the worst I’ve seen for sure. Oil cooler looks to be the top culprit   | ||
|  13th Feb 2025 9:43pm |
| diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 48      | I have order the two wee seal the BS611 ones, will start there as cheap, likely?
|  14th Feb 2025 12:59am |
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1032      | Rear Propshaft Bearing - they don't last that long I am afraid - sorry  | ||
|  14th Feb 2025 1:43am |
| diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 48      | So I have got the vitron seals for pipe, but is the recommendation to do the oil cooler at same time or just try oil pipe seals since can be done quicker, whats the general consensus. I was planning to do a full service anyway, so am I best just getting cooler and just doing it for peace of mind.
|  15th Feb 2025 8:13pm |
| mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8002      | It’s def oil cooler. Amount of oil would not come out of the pipe seals, but good practice to do those whilst you are at it.
|  15th Feb 2025 8:23pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Check oil when cold. Should be a couple of notches above mid way. Anymore and will show overfilled when not. Best way to check I’ve found   | ||
|  15th Feb 2025 8:25pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Do the oil cooler. New cooler and seals etc. Do the Viton ones at same time.
|  15th Feb 2025 8:27pm |
| diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 48      | Thanks, am thinking I would just be worrying about it, where is best to get it and do I need genuine one? I took pollen filler out at scuttle at had a nosey down back with mirror, there is defo oil around and on that pipe but think there was semi dry oil on cooler at front end opposite side from pipe and also same on top of cooler so guessing safe to assume between your experience and what I am seeing that best to change cooler, thanks
|  15th Feb 2025 8:28pm |
| DrRob Member Since: 16 Apr 2015 Location: Petersfield, Hampshire Posts: 4352      | Nissens is fine from site sponsor Advanced Factors. Gone to a good home: 2011 4.4 TDV8 Vogue SE Buckingham Blue with Ivory and clear glass = "Rory"
|  15th Feb 2025 8:30pm |
| diabloam Member Since: 22 Oct 2024 Location: Isle of Lewis Posts: 48      | will go for that
|  15th Feb 2025 8:55pm |
| AndyRoo Member Since: 06 Dec 2023 Location: Gloucester Posts: 709      | When changing the oil cooler assy, as well as the 2 rear pipe oil seals you should also change the water feed O ring on the right side of the cooler as you face the car, it's a push fit right angle connector and the original O ring will be squared and hard when you remove that plug and will just leak coolant if you don't change it.
|  15th Feb 2025 9:37pm |
| Posting Rules
