![]() | Home > Maintenance & Mods (L405) > L405 Handbrake Woes |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 385 ![]() ![]() ![]() |
As far as I am aware handbrake motors are not coded, I've changed several over the years and never had an issue, albeit I fitted genuine items. Never seen any codes from them once replaced. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
sgorianin@gmail.com Member Since: 11 May 2021 Location: London Posts: 36 ![]() ![]() ![]() |
If you replaced control module used from different car um afraid this fault will be still present. You can try to refresh module with your own vin number but it is 50/50 success as majority of the modules can be only done it ones since new.
Correction for my reply. I just remembered that once I
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1776 ![]() ![]() ![]() |
As per 4RRS, I’ve changed the motors on mine before, but you do have to put the handbrake into service mode before swapping out, did you do that? Maybe if you put back into service mode then re-initiate, all may be OK? I don’t think they are coded at all. V6 Vogue - “Less is More” - less to go wrong! |
fisha Member Since: 25 Sep 2009 Location: Scotland Posts: 1510 ![]() ![]() |
Is the error coming up under the parking brake section on the diagnostic tool? Cause it apparently relates to the blind spot mirrors:
The potential problem could be to read code number with 3rd party device, which can have different list of faults in the system.
Whilst I can understand that error code <> description associations might vary between devices, vehicles and manufacturers, ( and potentially could be wrong associations ) I find it hard to believe that the actual error code value that Rallyman's Autel is reporting back is wrong.
And in the error code comments, U3000-78 it mentioned 40 mins. Has the car been driven for an hour yet to let it do a full auto alignment ? Which is why I ask about whether the errors are categorised on the Autel. V8 or else ... |
What is my personal thought is that the blindspot system is not related to the parking module. So conclusion: fault is in different module or fault has different code. As I said and others also, replacement of the parking motors can't trigger this fault unless they are already not working. To replace parking module from different car won't trigger on dash fault only fault wrong vin or associated with this faults. BUT module WILL work as it should(checked few times with different components) and will keep fault appearing in sdd in dtc.
Also from my personal experience Chinese stuff doesn't want to work on this vehicles very occasionally it might work but not long. And I doubt so anybody of us will treat father's car with this s**ty stuff IMHO. |
