Home > Maintenance & Mods (L322) > Rusty upper tailgate
Koeni
Netherlands 2009 Range Rover Westminster 5.0 SC V8 Santorini Black
I discovered that the upper tailgate from my MY2010 Westminster is slightly corroded, what a surprise.
There is only corrosion on both edges on the inside (seam?) and around the locking mechanism.
I already used a can of Dinitrol ML to treat the inside of the body panel.
How should I proceed to treat the corrosion in the area as shown in the picture?
Post #643200 17th Sep 2022 2:38pm
T4ls
United Kingdom 2011 Range Rover Vogue 4.4 V8 Buckingham Blue
hello, i know this is an old post but id love to know of you managed to correct this and if so how?
Post #675769 17th Oct 2023 10:25pm
Once the rust is visible on the inside of the tailgate then it is too late to treat it successfully, anything you do will just "slightly" postpone the inevitable, the only way to fully cure it is to cut off the bottom outside section of the tailgate, sandblast all the rust off the frame and weld in new metal then treat it all to a good dose of rust prevention...
The rust has developed between the outer and inner skin and once it's there you can't get rid of all of it without surgery... it only takes one crumb of old rust left behind for it to continue to rust....
Keep an eye out for an early tailgate with no rust, the early ones were made out of better quality steel and had some rustproofing.... Thumbs Up Pete
-Click here for Thread-
Post #675814 18th Oct 2023 2:33pm
JayGee
A rusty tailgate is a badge of honour. It proves you are a dedicated L322 enthusiast and not just any old SUV owner. 2012 TDV8 Vogue (L322)
Post #675818 18th Oct 2023 3:26pm
Rex the RR
United Kingdom 2019 Range Rover Autobiography 5.0 SC V8 Santorini Black
That did make me chuckle and l totally agree!
Post #675849 18th Oct 2023 9:22pm
jjfang
United States 2012 Range Rover HSE 5.0 V8 Santorini Black
Depending on how bad it was it could have maybe been 'saved'. Depending on how the rust was on the inside of the tailgate. I'd say your best bet is to have a shop grind all the seam sealer off and open the lip to see how the rust is in there seam. Hopefully if not bad or just concentrated around the seam then you can treat it, reapply seal sealer, and repaint and get some more time. But I HIGHLY suggest a yearly treatment of cavity wax of sorts in the upper tailgate.
Otherwise your only option is to find a new/used tailgate that is rust free and start treating it from there.
Post #676051 21st Oct 2023 4:28pm
pcourtney
How much is required, looking inside there seems to be quite a void, would 1L of Dinitrol ML Brown spray do it do you think ?
I have already sprayed in the Dinitrol RC900 ( Rust Convertor ) , and it is slowly dripping out onto my lower tailgate ( I put old towels and rags on the lower tailgate to catch all the drips Smile
https://www.matthys.net/en/dinitrol-ml-cav...n-18193181
Post #712148 18th Feb 2025 4:06pm
Until it comes out all the drain holes... 1ltr will be plenty...
When you have done that, take off the sill covers and inject all the body sections you can, especially the rear part... Thumbs Up Pete
Post #712152 18th Feb 2025 5:01pm
pcourtney
I can see the two square drain roles ( they are also getting a little rusty) , but how is water getting into the tailgate box section where it requires those drain holes - a bit puzzling to me ?
I can see along the seam, that the tailgate closes onto the lower tailgate, and there is going to be surface water from driving, and salty water in the winter perhaps, and whenever the rear wiper is used and the water nozzle, a fair amount of surplus water will be raining down onto that weatherstrip, and I get that, and rust will get a hold along that horizontal surface, but how am I ever going to stop that happening, even if I do a really great job getting it back to bare metal and painting again, does anyone have a neat solution for this seam area ?
Post #712326 20th Feb 2025 4:42pm
pcourtney
won't the cavity wax block the drain holes if I do that ?
where does the water come from that makes the drain holes a necessity - or are they superfluous ?
Post #712343 20th Feb 2025 9:31pm
