Home > Technical (L322) > IIDTool from gap diagnostics ***Q & A ***
Page 49 of 49 <123 ... 474849
pcourtney
2004 car - just used the IID to scan for any errors/faults, most of them I can work out, but one of them seems to be fairly uncommon - with no resolution
BPM Body Processor v10 0x38 Open Circuit Activation SRA DRM 2 DS2 1 Fault
Have searched on here, and googled, but am none the wiser, just posting here in case anyone can shed some light on it, thanks
Post #699780 8th Sep 2024 4:31pm
pcourtney
Is this thread no longer monitored by the good people at GAP ??
Post #702700 20th Oct 2024 3:18pm
PDC
United Kingdom 2010 Range Rover Autobiography 5.0 SC V8 Barolo Black
Hi all. I'm trying to find the live value settings within my IID Gap tool for my air compressor and can not. At present time the Gap tool states that it has an Hitachi compressor fitted, but I have noticed at some point in time someone has replaced it with an Arnott compressor that is modelled of the AMK Compressor.
My question is do you think I can't see the live values because maybe I should select within the settings that it has an AMK compressor fitted? I'm a little hesitant in re-flashing for AMK as it states in doing so it "MAY" render the car inoperable.
Just a foot note, at the moment the air suspension is all working fine, I just would like to see the live values for the compressor.
Many thanks, Paul. 2010 RR Autobiography 5.0 SC
2020 F-Pace SVR 5.0 SC
2018 RRS HSE Dynamic 3.0
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #706325 7th Dec 2024 4:49pm
PDC
Just thought I would try again to see if anyone had any ideas on my above post. Thumbs Up 2010 RR Autobiography 5.0 SC
2014 Disco XXV
2011 Disco 3.0
2009 RRS HST V8
Post #708387 5th Jan 2025 6:42pm
i have no idea but you could email Pat @ GAP for an answer.. ... - .- -.
Post #708390 5th Jan 2025 7:09pm
Bazzer58
United Kingdom 2012 Range Rover Autobiography 4.4 V8 Zambezi Silver
L322 4.4 tdv8 Aukiliary heater using GAP IID tool
I have a new to me, 2012 L322 with Auxiliary heater with remote. And a new to me iiD tool.
If I use the remote, the internal fan on the car starts, but no heat.
Can I use the iiD tool to see all the live values for the system to see which bit isn’t working?
Thanks.
Post #708705 9th Jan 2025 4:27pm
Japseroony
England 2019 Range Rover SVAutobiography 5.0 SC V8 Indus Silver
Just bought a 2025 FF l460 and would like to know what the GAP took can help with?
Would like to set the auto start/stop to off and have the car remember the last setting such as off or on and also have the drivers assist settings remembered?
Look forward to any advice/replies Thumbs Up "UNDERSTEER" ----is when you hit the fence with the front of the car.
"OVERSTEER" ------is when you hit the fence with the rear of the car.
"HORSEPOWER" ----is how fast you hit the fence.
"TORQUE" -----------is how far you take the fence with you.
Post #711389 8th Feb 2025 4:31pm
JMC
Scotland 2012 Range Rover Westminster TDV8 Orkney Grey
I have a GAP IID BT and was wondering if it would act as a generic reader / clearer of fault codes with other vehicles?
My Father in Law has a 2016 Ford Kuga which is showing faults and we just need them cleared. The dealer wants the car booked in for £100's just to plug in an OBDII The older I get, the more I realise that people confuse wrinkles for wisdom Smile
Post #712278 20th Feb 2025 7:49am
TomSlav45
Australia
2018 RR Sport L494 SE TDV6. I have the G4 IIDTool, and previously used it on my 2014 L494 Sport HSE SDV6 to lower all around using the easy “adjust all heigh” by pressing the down arrows and linking both axles together, by -32mm. After having the wheels aligned, it drove like a sports SUV, handles still beautifully I still have it; and it looks superb!!!
On my newer 2018 SE TDV6, For the life of Big Cry me, I’ve updated my G4 tool etc, I CANNOT GET the front axle to respond to the down arrow button to lower the front suspension, at all!! Only the rear axle responds and actually goes down, I’ve tried linking and unlinking the axles, the front will just not respond and it stays on “0”, it won’t go anything lower than “0”. Can anybody help me out here please?
Access mode works fine, the front lowers that way, but of course it’s TOO LOW and of course comes back up at a certain speed. Surely there’s got to be a way to get the stubborn front axle to respond to the tool!! I’ll attach a photo of what I mean
Post #722553 8th Aug 2025 6:58pm
