![]() | Home > Technical (L405) > Slight intermittent burning smell |
supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3921 ![]() ![]() ![]() |
Mine also does this, no drips on the drive either, I am suspecting the oil cooler gasket - I may be wrong I usually am |
diesel Dave Member Since: 14 Aug 2015 Location: Stockport Posts: 489 ![]() ![]() ![]() |
You can get a smell off the regen as everything gets to a silly temperature to burn the soot off, but its not an oil smell, hard to explain but just a fumey burning smell, unless you have a slight leak that’s getting oil on the exhaust or crossover pipe, then smells when you regen or work it harder like towing or long run. |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8760 ![]() ![]() ![]() |
Yeah it’s a funny smell, halfway between oil and tarmac….. very faint at the moment but it was quite noticeable before Xmas when I went down to Bath. Possibly makes me think leak as that was at the same time as the EGT sensor went. So in theory…… couldn’t regenerate with the duff sensor? There is nothing that can't be fixed with a hammer😜😜
I’ve ordered a cooler and some O rings, and will do them in the next couple of weeks. It was on my list of preventative jobs, time to get the spanners back out……
Think your doing the best thing TBH by starting with the oil cooler, its the most probable cause and is eliminated if the problem should continue. |
Yeah, doesn’t look too hard. I’ve had all the plenum and throttle body off a 4.4 when I had my 322, so about 50% of the job…..iirc it wasn’t too bad. I’m thinking the wiper arms might be the hardest bit to get off if they’ve seized on…… |
comports Member Since: 20 Dec 2010 Location: Colchester Posts: 1761 ![]() ![]() ![]() |
NMJ,
There is a write up on here Ash, it’s in the Wiki. I added a few more steps for the 405 to the end of it as it was for the 322 originally.
