![]() | Home > Maintenance & Mods (L405) > Blind spot monitoring fault |
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 442 ![]() ![]() ![]() |
If the car has been told by modifying the ccf that it now has a towbar fitted the BSM system won't work if you have something connected to the towbar electrics (trailer etc.) and you'll get the dots in the mirrors to alert you to this. You'll also have no rear parking sensors when tow bar electrics are connected, if nothing is connected then the BSM and rear PDC should work as normal. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
EV84 Member Since: 20 Jan 2024 Location: Lincoln Posts: 4 ![]() |
Yeah trouble is the fault is in regardless of something being plugged in or not. |
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35871 ![]() ![]() |
disconnect the towbar wiring and see if that helps. ... - .- -.
Revisiting this again as I do miss having the blind spot monitoring on the motorway.
Monty+4 Member Since: 25 Oct 2023 Location: Argyll Posts: 24 ![]() ![]() ![]() |
Without any trailer connected, do you get the green trailer connected light on the instrument cluster when indicating left or right? |
