Home > Technical (L322) > Well it happened, top coolant hose
Barmybrummie
United Kingdom 2011 Range Rover Vogue SE 4.4 V8 Santorini Black
Had a very very slight coolant leak, topping up every few months when it told me on the dash. Found out where it was coming from and low and behold the hose coming from the right to the centre of the engine on the top hose just broke away as soon as I touched it. That's where the leak was dripping from so I'm rather lucky it didn't go while I was driving along. Rather bizarre how brittle it was just to break like that with the softest of touches. And looking online, I can't just buy the centre piece with the 2 hoses on it but the whole hose itself. Now, there's a way to rip us off in the parts department when clearly you can remove said broken piece from the main hose.
Post #712522 22nd Feb 2025 6:20pm
mjdronfield
Indeed. Seem to think it was around £90 when mine broke a few years ago, maybe 4 or 5 years…..
A few folk on here have done an alternative fix, might be in the Wiki, can’t remember.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #712528 22nd Feb 2025 7:20pm
JCW
See here - easy & cheap fix Thumbs Up
https://www.fullfatrr.com/forum/topic48509.html Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #712529 22nd Feb 2025 7:26pm
Barmybrummie
Thanks guys, but unfortunately I won't be able to do a temporary fix as I have to take my daughter back to Lichfield tomorrow so not got the time for the repair. Shame it didn't happen early this morning otherwise I'd had plenty of time to sort. Oh well, see if I can use the works van and just order the part There's a land rover parts shop in tredegar called foundry 4X4 which I didn't know about until today. But the repair is good to know should it happen again in the future.
Post #712533 22nd Feb 2025 8:13pm
mjdronfield
Foundry have been going for years. Sure I’ve ordered from them at least once.
Previous cars :
1992 BMW M5 3.8
1988 BMW 735i SE
Post #712552 22nd Feb 2025 10:41pm
Barmybrummie
How easy is it to get to the bottom hose and remove it? Looks like it's a bit of tight fit under the throttle body. Would it just be worth replacing the centre piece as it looks a lot easier to do rather than replace the whole hose?
Post #712609 23rd Feb 2025 2:23pm
GraemeS
Australia
The fitting at the engine end is easy enough to remove by lifting the retaining clip, but first remove the air intake hose.
Post #712631 23rd Feb 2025 8:32pm
Barmybrummie
All fixed, bought the part from foundry 4X4 in tredegar for £55. 20 minutes to fit and bleed and now all good. Thanks guys.
Post #712717 24th Feb 2025 8:59pm
