![]() | Home > Technical (L405) > Broken down in France - help diagnose my problem |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2762 ![]() ![]() |
Hopefully just an inlet / turbo hose popped off somewhere. Oil on a hot exhaust manifold would create smoke.
4RRS Member Since: 13 Apr 2022 Location: Crudgington Posts: 438 ![]() ![]() ![]() |
Gearbox oil cooler is mounted behind rad, so if a line to that has failed it would tally with the oil below the front bumper scenario. L405 SV Autobiography LWB SDV8, finished in Aston Martin China Grey by ETO division. |
Spridget Member Since: 09 Dec 2023 Location: Northumberland Posts: 203 ![]() ![]() ![]() |
Black oil seems to point to engine but why should things change when in gear? It seems that the engine is happy to tick over but the faults start when under load. Hopefully all will be revealed when the under shield comes off and hopefully it's something simple.🤞 |
Engine behaviour suggests an airflow issue. |
Vogue Member Since: 31 Jan 2008 Location: on the hill Posts: 3817 ![]() ![]() |
I had exactly these symptoms on my Defender last weekend. It was the turbo air hose which had blown off. The black smoke was caused by excess fuel being burned and not enough air getting to the engine. There was also virtually no engine power as the Turbo wasn’t able to pressurise the air intake system.
stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35858 ![]() ![]() |
you really dont want something like this to happen whilst on holiday..
caymanblack Member Since: 08 Dec 2015 Location: DEVON Posts: 1172 ![]() ![]() ![]() |
I hope its a simple fix E500 let us know how you get on. overfinch modified |
E500 Member Since: 10 Sep 2024 Location: Hertfordshire Posts: 87 ![]() ![]() |
Thanks guys. I had to abandon the car with the recovery company in northern France and rent a Clio(!) (all I could get on a Saturday…) to continue my drive to the alps.
EmiratesA380 Member Since: 14 Jan 2015 Location: england Posts: 361 ![]() ![]() ![]() |
E500
jez000 Member Since: 17 Apr 2009 Location: Yorkshire Posts: 747 ![]() ![]() ![]() |
Cant help with the fault but if you have a toll tag in your car remember to remove it if it gets recovered back to the UK |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3345 ![]() ![]() ![]() |
How much oil was on the ground in front of the car?
Still no update I’m afraid. I’ve no idea what’s going on with the car, all very frustrating.
knares Member Since: 22 Jun 2017 Location: Perth WA Posts: 834 ![]() ![]() ![]() |
O dear, following RR 2005 4.4 petrol
Well I wish I could tell you all what the problem was in the end, but I am still none the wiser.
