![]() | Home > Maintenance & Mods (L322) > Hood replacement won't open |
dingg1 Member Since: 29 Jun 2013 Location: PORTUGAL Posts: 1412 ![]() ![]() |
It'll be slightly offset, you will need an assistant to pull the release cable, if you push the bonnet near the pegs which secure into the front panel you should be able to get them to release, try from the side of the bonnet also, hopefully you can get it sorted
smellslikeespresso Member Since: 23 Feb 2025 Location: Norwich/Amsterdam Posts: 2 ![]() ![]() ![]() |
Ah, I had a bit of a play but I will go back with some more effort. There is some downwards movement when I push down around the pegs so I assume it just working that area? |
mjdronfield Member Since: 04 Nov 2011 Location: Derbyshire Posts: 8000 ![]() ![]() ![]() |
You need to try side to side I recon. Not had to do it but I don’t think up and down will help you… happy to be corrected though
BAZ8046 Member Since: 26 May 2023 Location: Chatham Posts: 51 ![]() ![]() ![]() |
Yes they are very sensitive to alignment.
