![]() | Home > General (L405) > SDV6 Prospective purchase |
bozmandb9 Member Since: 06 Dec 2010 Location: Wallingford, Oxfordshire Posts: 1055 ![]() ![]() |
Hi there,
Gremlin500 Member Since: 11 Mar 2022 Location: Newcastle, UK Posts: 1832 ![]() ![]() ![]() |
I’d be more worried if it had JUST had a new engine say within 20K miles.
Thanks for comments so far. The car with the replacement engine sold before I got to it. So still looking and trying to make my mind up between Tdv6 and SDV8! 2012 SDV8 Vogue SE |
Dolphinboy Member Since: 08 Dec 2009 Location: Bristol Posts: 3261 ![]() ![]() ![]() |
AFAIK the V6 doesn't have the stability system which makes the drive so radically better than the L322. Only the SDV8 has it I believe. |
Zebedee Member Since: 09 Jun 2016 Location: Cheshire/South Manchester Posts: 404 ![]() ![]() ![]() |
I wouldn't say the active suspension makes the ride radically better between the 4.4 and the 3.0. The difference is barely noticable on normal driving. The only difference I could feel was when pushing a bit around a corner, the 4.4 does feel more planted compared to the 3.0. On the plus side, you don't have to worry about the corroding pipes on the 3.0. Current:
Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1422 ![]() ![]() |
Check the service history like a hawk! MOT history for miles each year etc is it a city car?
Thanks Zebedee - is that the ACE Pipes? So is this a non issue if I get a TDV6, or was it an option on the V6 engined cars? 2012 SDV8 Vogue SE |
I found a really interesting post on the RRS forum which seemed to indicate that oil dilution can be largely avoided by using 5W40 oil instead of the recommended 5W30. Think it was from some research Range Rover World did. 2012 SDV8 Vogue SE |
Wow an oil that stops fuel dilution!
Giggle all you like, or read the article, and if you have any constructive criticism I'd be interested to hear, but it seems logical to me.
cass Member Since: 12 Oct 2011 Location: northumberland Posts: 782 ![]() ![]() |
Call me cynical but I'd always be suspicious of "research" showing how you must change your oil now on a website selling the product/service that this research recommends. |
toby1 Member Since: 24 Mar 2024 Location: West Berkshire Posts: 302 ![]() ![]() |
And it mentions buying Edge 5W40 C1 - which does not exist on Castrol's website, nor any other company AFAIK. Frequent oil changes are the key. 2012 Vogue TDV8 in Aintree green over sand |
www.fullfatrr.com/forum/topic69701.html
Yes correct, except it’s 5W40 C4.
