Home > Technical (L322) > Calibration Steering Angle Sensor
knares
Australia 2005 Range Rover Vogue 4.4 V8 Zambezi Silver
3.5 Calibration
3.5.1 Steering Angle Sensor ECU (L322-02, L322-06, L319-04)
Steering angle sensor calibration
This routine will calibrate the steering angle sensor center position.
Preparations
• Place the vehicle on a fl at and level surface.
• Ensure that your front wheels and steering wheel are straight before proceeding.
Use
This function is used when:
• The steering angle sensor is replaced.
• A wheels alignment is performed on the vehicle.
• It may be required if parts of the steering system have been replaced or removed.
Steering angle sensor renew (L322-02 and L322-06)
T RR 2005 4.4 petrol
Any spelling mistakes are the fault of spellchecker
Previous MG J2, CITROEN light 15 x 2 gone unfortunately
Present MERC 180e, RANGE ROVER L322, JAGUAR XJS, MERC 280SE, MG F, JAGUAR S-Type 6v 2003, jaguar s-type 8v 2004, Ford Cougar
Post #712685 24th Feb 2025 12:35pm
knares
so, now i know RR 2005 4.4 petrol
Post #712686 24th Feb 2025 12:36pm
knares
to me, its as clear as mud, i can only assume others understand it and know what steps to take RR 2005 4.4 petrol
Post #712817 26th Feb 2025 6:48am
dingg1
Just follow the prompts from the iid tool, can't remember doing it tbh, but it could be as simple as full lock left, pause, full lock right, return wheel to centre, job done...
Post #712831 26th Feb 2025 11:51am
knares
hi, as i understand it, that doesn't program a new steering angle sensor and it appears having the track adjusted, the sensor could need reprograming RR 2005 4.4 petrol
Post #712844 26th Feb 2025 12:46pm
knares
after a couple of emails back and forth to gap, i now know, just half a dozen words,thats all it took RR 2005 4.4 petrol
Post #713210 3rd Mar 2025 5:24am
