Home > Maintenance & Mods (L405) > Electrics shut down and won't start
Calvey
United Kingdom 2016 Range Rover Vogue SE SDV6 Carpathian Grey
Electrics shut down when trying to start my L405 4.4TDV8 2016
Its not the batteries but every time I go to start it, everything lights up but before the engine has a chance to crank, everything shuts down. In the past it happened very occasionally, but always started on the second attempt..
Now it won't start at all and has been carried off to my local independent, but they are scratching their heads.
Anyone had anything similar?
Calvey 2016 L405 SDV8 Vogue SE
2012 Range Rover TDV8 Westminster Santorini Black
Post #712793 25th Feb 2025 8:12pm
JCW
Assuming the batteries are definitely ok and they’ve checked any fault codes, it may be worth checking the earth points situated behind the front wheel arch liners, as these are exposed and can become a bit crusty. Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #712796 25th Feb 2025 8:32pm
Calvey
Thanks
The batteries are 100% and it behaves as normal if you switch the ignition on without the footbrake on. However the garage is saying that when you try to start it,the electrics are not on long enough to register a fault code. 2016 L405 SDV8 Vogue SE
Post #712799 25th Feb 2025 8:48pm
JCW
They should be able to read any logged fault codes without starting the engine, just with the ignition switched on. Jonathan
Post #712800 25th Feb 2025 8:51pm
Calvey
Just as an update, my garage found the problem. Not sure how, but it was a faulty teletrac tracker that was the culprit. 2016 L405 SDV8 Vogue SE
Post #712974 27th Feb 2025 10:08pm
