Home > Technical (L322) > Very noisy steering wheel 4.2 S/C
tspd
I’ve noticed a more frequent but intermittent sound coming from my steering wheel when being moved. At times the sound is completely absent!
Video attached shows it best. Have check power steering fluid level and seems ok. Any ideas!
https://youtube.com/shorts/XDctT5jxPZg?si=5X3vy5EyNg7pOxVC L322 2007 S/C 4.2L (first full fat)
135k miles and counting
Buckingham Blue
Post #711897 15th Feb 2025 4:34pm
tspd
Update on this. The noise was present prior to major work being recently done (rear subframe off, rear brake lines done, lanoguard, transmission fluids etc.) but since this work I've noticed the steering wheel is off centre as well. I'd say about 4-5 degrees tilted RIGHT to keep the car going dead straight on level road.
The wheel has never been off as far as I know and I don't recall it being like this before the works. I went and got it centred with Hawkeye after the works and picture below is how it is now, but even after that the wheel needs to be tilted right to maintain straight drive. Not sure what to do next - was the alignment not done with the wheel central perhaps? The alignment is all green now but not perfect as you can see.
Presumably I can't (and don't want to) fix this by somehow removing the wheel and re-centering that way? Suggest another alignment?
And - any idea on the noise? Steering seems a bit heavy...
Thanks!
Buckingham Blue
Post #712776 25th Feb 2025 5:32pm
philip1972
France 2006 Range Rover Autobiography 4.2 SC V8 Java Black
I took my wheel off and recentered no problem.
It helped alot having an airbag removal tool.
Post #712788 25th Feb 2025 7:27pm
Sandyt
Sometimes when they do the alignment they fix the steering wheel in place with the engine off and when they start the engine the wheel moves in out up down to where ever the memory tells it so it ends up off centre for the alignment - hope I have explained it ok
Post #712794 25th Feb 2025 8:25pm
Paddy X350
Ireland 2008 Range Rover Vogue TDV8 Stornoway Grey
I have a 4,2 supercharged Jaguar X350 XJR. Mine and other jags can suffer from exactly that sound. Jag issued a technical bulletin about it and there is an jaguar/Landrover additive that you can get and add to the power steering fluid.
If you search for JTB00055 on the web you will find the technical bulletin detailing the procedure/details of the additive. All the best
Chris
Others;
1966 Jaguar 3.4 S type
1992 Jaguar Xjs 4.0 Coupe
2003 Jaguar Xjr
Post #712804 25th Feb 2025 10:01pm
kevinp
If I ever have to centre the steering wheel I adjust the track rod ends by doing one in one direction and the other in the opposite direction equal amounts.
Post #712841 26th Feb 2025 12:31pm
Sandyt
I also replaced the steering wheel squib
Post #712842 26th Feb 2025 12:36pm
batfink
2004 Range Rover Vogue 4.4 V8 Adriatic Blue
How long since the power steering fluid was changed?
I wonder if it's to do with age of the fluid. I think it's 150k miles that's recommended by Land Rover.
Post #712875 26th Feb 2025 7:02pm
