Home > Technical (L405) > Which Oil…..and a coolant rabbit hole….
Ok, I know this will open a can of worms, but……
4.4 SDV8 which oil are folks using.
The spec is a Ford WSS M2C 934B
The recommended is a Shell Helix Professional AJ-L 5W30
This seems to be like rocking horse 💩. So as an alternative Opie Offer several oils to spec:
Motul
Fuchs
Comma
Petronas
Valvoline
Liquimoly
All meet spec aparently, which would you choose?? There is nothing that can't be fixed with a hammer😜😜
Last edited by northernmonkeyjones on 28th Feb 2025 8:28pm. Edited 3 times in total
Post #712923 27th Feb 2025 11:11am
BAZ8046
I use Smith & Allen Momentum C1 5w30 for both the L322 & D4.
If you buy it 20l at a time it works out around £4.25 per litre. 2012 TDV8 4.4 Westminster Santorini black
2016 Discovery 4 Landmark
2002 Defender TD5
Post #712925 27th Feb 2025 11:49am
will308f
United Kingdom 2014 Range Rover Autobiography SDV8 Loire Blue
snap used it on my l322 and also now on my l405 Thumbs Up
Post #712928 27th Feb 2025 12:26pm
Will have a Google. Thumbs Up There is nothing that can't be fixed with a hammer😜😜
Post #712929 27th Feb 2025 12:28pm
Silverstone
United Kingdom 2016 Range Rover Vogue SE SDV8 Loire Blue
Changed the oil and filter in my MY2016 SDV8 and used Petronas Syntium 5000 FJ 5W-30. Purchased 10 litres from Opie Oils for £52.48 (incl delivery). "There is no replacement for displacement" - W O Bentley
Post #712932 27th Feb 2025 1:00pm
Kot
@Silverstone +1 Thumbs Up 2018 SE SDV8 4.4 Byron Blue
Post #712938 27th Feb 2025 1:38pm
caymanblack
And me for the above two. Thumbs Up overfinch modified
Post #712954 27th Feb 2025 6:20pm
Gremlin500
#3 for this one, it’s the right spec and the best value if you’re changing it twice a year as you probably should be, there’s really little point in using anything too expensive IMHO. V6 Vogue - “Less is More” - less to go wrong!
Post #712964 27th Feb 2025 8:49pm
toby1
Is there a 'bad' oil on sale any more? The days when we fretted over mineral oil being as viscous as water are long gone.
FWIW, S&A seems to be the best value, especially if one buys a 20 litre drum. It's a bargain for two oil changes, as mentioned above.
I recently bought some 10W40 from S&A for my SL at £44 for 10 litres. I am happy with that and if my engine grenades, it won't be due to the oil. 2012 Vogue TDV8 in Aintree green over sand
Post #712970 27th Feb 2025 9:22pm
Gremlin500
3 oil changes if you have a V6! Serious value! Thumbs Up V6 Vogue - “Less is More” - less to go wrong!
Post #712975 27th Feb 2025 10:18pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
I also use Smith and Allen. I use them for all my oils.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #712976 27th Feb 2025 10:19pm
Tdtj
Plus another for smith and allen Thumbs Up 2016 4.4 diesel
Post #712997 28th Feb 2025 12:07pm
Ordered some smith and Allen. 👍🏻
Arrived today. Very quick dispatch direct from their site. Had a good read of their website and there is some interesting stuff on there.
I’ve now gone down a coolant rabbit hole…….
Book says JLR.651.5003 or XLC. The only one I can find which directly says it’s that spec is Mannol AF12+
Just looks like pink OAT to me……. There is nothing that can't be fixed with a hammer😜😜
Post #713025 28th Feb 2025 7:37pm
kevinp
I use Halfords OAT. Thumbs Up
Post #713032 28th Feb 2025 9:00pm
Had some of that in the garage, needed a top up the other day, 1/2 a cup, but I’m going to drop some fluid out to do the cooler tomorrow, so basically a full swap.
Why it’s not a Ford spec I don’t know as it’s a Ford engine…… the oil is a Ford spec🤣 There is nothing that can't be fixed with a hammer😜😜
Post #713034 28th Feb 2025 9:17pm
