Home > Technical (L405) > Access mode
Tiny Timmy
Access mode
Can you stop the access mode coming in every time you stop the vehicle?
Mine always drops everytime I stop and open the doors.
And then everytime I get into drive after being parked up for a while, then it has to pump up to normal ride height !!,
I've looked everywhere in the hand book and can't find anything Shocked Rolling Eyes
Post #712944 27th Feb 2025 4:35pm
auto access setting is in the speedo dash menu..
vehicle
convenience
select vehicle access ... - .- -.
Post #712946 27th Feb 2025 4:38pm
Tiny Timmy
Thanks Stan, so you can turn it off then ?
Post #712948 27th Feb 2025 5:01pm
yes you can... Thumbs Up ... - .- -.
Post #712949 27th Feb 2025 5:04pm
Tiny Timmy
Great thanks again Stan
Post #712951 27th Feb 2025 5:33pm
Matt Buckland
United Kingdom 2017 Range Rover Autobiography TDV6 Santorini Black
When I first got my L405, I also was about to de-select auto access height, thinking it was putting undue strain on the bags and unecccessary cycles on the compressor….but a wise friend countered “use it or lose it” , so I left it alone.
Might be an idea to cycle through the heights periodically, just so the compressor sees some active service. L460 460e PHEV AB. Belgravia green.
Previous toys:
L405 2017 TDV6 AB
4.4 TDV8 Westminster. Santorini Black
1976 Lightweight
4.0l P38
2 Disco 3s
Jaguar XJ6 (X350)
Jaguar XJ8 (X308)
Jaguar XK
Jaguar XK8. Confirmed JLR nut.
Post #712952 27th Feb 2025 5:47pm
Tiny Timmy
Yeah good idea, I just don't need it everytime,must wear the pump etc eventually though
Post #712955 27th Feb 2025 6:20pm
Gremlin500
Better than the pump seizing due to lack of use? Whistle V6 Vogue - “Less is More” - less to go wrong!
Post #712966 27th Feb 2025 8:57pm
Tiny Timmy
Maybe, still think it would wear out quicker on the sort of journeys I do. But I will run it now and again Thumbs Up
Post #712967 27th Feb 2025 9:01pm
ChrisJC
United Kingdom 2014 Range Rover Vogue SDV8 Aintree Green
The pump won't seize through lack of use! Each time you have a different load in the vehicle it will inflate or deflate the system. I think it also drops down at motorway speed and rises again when you slow down.
Chris. L405 - 4.4SDV8 Vogue
P38 - 4.6V8 HSE
Land Rover series IIA V8
Post #712977 27th Feb 2025 10:20pm
Tiny Timmy
Like it Chris , sounds good
Post #712980 27th Feb 2025 10:33pm
Spridget
United Kingdom 2015 Range Rover Vogue SDV6 Corris Grey
vehicle
convenience
This must be another feature that my bog standard base model doesn't have. I have to press the button every time and on the 90% of occasions when I forget, filthy looks are forthcoming from the passenger seat. It would be handy if it operated every time. Maybe I can select it using iiD.
Post #713029 28th Feb 2025 8:23pm
i think this feature came in on the facelifts [2017 onwards ] ... - .- -.
Post #713044 28th Feb 2025 10:08pm
Dolphinboy
Ive got it on my Nov 2015 (2016 MY)
Post #713049 28th Feb 2025 10:38pm
ChrisJC
I checked the owners manual last night, and it definitely goes up and down of it's own accord depending on road speed, so the system will always be used even if you never adjust the height manually.
P38 - 4.6V8 HSE
Post #713065 1st Mar 2025 9:16am
