Home > Technical (L322) > Suspension fault
watts
United Kingdom 2012 Range Rover Westminster 4.4 V8 Bonatti Grey
Suspension fault
Suspension fault garage hooked up a snap on obd revealing no voltage to exhaust port any ideas on where to look and what cables go to exhaust port colour and so on or is there a fuse I suspect the spare wheel might of crushed some of the loom feeding the compressor but I can’t see any breaks l322. Westminster 2012 it look like the hitachi compressor . I’ve also got an autel maxis 200 with lr software seems good I haven’t made friends with it yet navigating through and interpreting all the info , is the gap better thanks
Post #712990 28th Feb 2025 11:17am
watts
Post #712991 28th Feb 2025 11:18am
mjdronfield
Not an expert but I’d be undoing the exhaust filter, as that usually gets blocked over time.
Easy fix if it’s that.
https://www.fullfatrr.com/forum/topic23038...p;start=45 2011 Range Rover Vogue SE 4.4 TDV8
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #713008 28th Feb 2025 4:35pm
watts
Thanks , I have tried that no different
Post #713016 28th Feb 2025 5:53pm
