![]() | Home > General (L405) > Hybrid - which engine? |
| supershuttle Member Since: 20 Mar 2011 Location: Lancashire Posts: 3962
I think it may well be inevitable that when I change my V8 diesel I'll be getting an electric RR as my driving pattern has changed considerably recently. I do lots of very short journeys (less than 10 miles) now with the occasional (fortnightly) jaunt down a motorway. On the motorway I tend mostly to drive around 60 - 70 mph to keep out of the way of the HGVs with the occasional need for speed when overtaking. The motorway journeys are a minimum of 20 miles with another 20 getting to the motorway. I initially turned my nose up at diesels because of the potential oil dilution problem I read so much about but then I realised that the short journeys would be completed on electric only so this might not be an issue, I'm not even sure they all have DPFs either. I never tow, never go off-road so my current car is probably a bit of overkill although the shove in the back when you put you foot down to overtake is very nice.
| Philip Member Since: 05 Jan 2010 Location: UK Posts: 2626
Cranks aren’t the worry with 2l Ingeniums (and I haven’t really read much about P400e engine issues). |
As our America friends would say thats quite a chunk of change extra and I like the L405 much better that the L460 (I'm sure it will grow on me). Obviously another option for the L405 would just be a 5L petrol. Geoff |
| andyleeds Member Since: 31 Dec 2010 Location: west yorks Posts: 982
I was thinking about hybrids but am being put off by the costs of the repairs to the hybrid unit when it goes wrong? |
| Chalky Member Since: 10 Feb 2018 Location: Marshfield, Bath Posts: 931
I was loaned a P400E Sport when my FFRR went in for crash repairs (not my fault!! |
| V8 Bob Member Since: 15 Mar 2018 Location: Cumbria Posts: 381
Early pheasant had a lot of trouble with the electric heaters failing …..is this still the case or have the manufacturers solved the issues? This problem was not limited to JLR but across a wide range of Hybrids who used the same technology for heating when in battery power. 2012 tdv8 Westminster arrived Jan 19 gone Dec 23
| Kot Member Since: 10 Mar 2021 Location: Broadland Posts: 1442
So wanted to add Tinmans thread but the video doesn't work !!!!! anyone got another link?
| stan Site Moderator Member Since: 13 Jul 2010 Location: a moderate moderated moderator moderating moderately in moderation Posts: 35874
i read somewhere that around 70k miles you start having problems with the battery...
| JW911 Member Since: 09 Dec 2008 Location: Hampshire, UK Posts: 268
I’m now a month into a 2021 P400 (not e) petrol. It’s giving similar mpg to my previous TDV8 so maybe worth a thought. Straight six as well. |
| Tinman Member Since: 22 Mar 2017 Location: kent Posts: 1210 |
Hi All, What was reported by High Peak Autos is that we should expect that most Hybrid's will fail after 70k miles, as with any electrical component they tend to have problems?
| chicb Member Since: 28 Nov 2019 Location: Dundee Posts: 141
I'm thinking that the p400e will suffice for my needs. As my old boss used to say "there's always a good reason not to do something" and as chicb says the internet will give you those reasons. I bet there are hundreds of satisfied customers with p400e's blissfully unaware that the internet says they should have had a new battery |
Geoff,
Are there any 10Y old P400e yet? 2018 SE SDV8 4.4 Byron Blue |
