![]() | Home > Technical (L322) > Help with suspension height |
mrblonde Member Since: 24 Jan 2012 Location: Cambs Posts: 766 ![]() ![]() ![]() |
pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1015 ![]() ![]() ![]() |
You can try two things
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
When my 06 Td6 has been left for months whilst at sea it can be reluctant to alter the height, a steering angle sensor reset usually does the trick, full lock/hold, centre/hold, opposite lock/ hold, back to centre.
Thanks guys
What are your measurements for all four wheels from the hub centres ( ie the middle of the centre wheel cap) , below is a table of what the measurements should be from the wheel arch (the bottom side of the wing) to the centre of the wheel caps
All 4 corners are about 640mm when measured from bottom of wing to centre of the wheel cap.
Have you got into the boot and taken the cover off the compressor, and removed the silencer exhaust ( it looks like a cork shape type brass cone ) , remove the exhaust and using a small drill bit- 2mm is good, drill down the middle and then place it back in the compressor housing, see if the suspension then drops back to "Standard Height"
Paddy X350 Member Since: 15 Nov 2023 Location: Wexford Posts: 63 ![]() ![]() ![]() |
Probably an obvious one but...Have you moved/driven it? I know that when my suspension raises due to jacking and wheel removal it rights itself after being driven a short distance.. All the best
Good shout sir... ![]() But to add, the suspension will work with the silencer removed albeit very loudly! When removed, try blowing through it... They always block up! even on the 405's its no different! ![]() ![]() ![]() ![]() |
Quick update guys, and for anyone who ever searches ‘suspension height’
