![]() | Home > Technical (L405) > Reccomend recon engine 2017MY RR Autobiography SDV8? |
SS.Lyria Member Since: 01 Dec 2016 Location: London Posts: 269 ![]() ![]() ![]() |
This was for a 2.0 ltr ingenium engine so I assume availability is quite good. I was offered a very good px for my FF so jumped in a bit lively. To be fair and forgetting the atrocious reliability I found the engine ok, lively off the mark, good motorway cruiser and could achieve 50mpg on a steady run. Even manages low 30’s mpg around town. @Chef45, happy with it so far as it hasn’t broken down ![]() Garage in Maidstone done the job. Initially it was diagnosed as timing chain failure by the AA which is why it went to a ‘timing chain specialist’ but investigation proved different. Garage has had many 2 litre and the V6 3 litre LR’s in for new engines, when I picked mine up they had 3 on the ramps ![]() On the 2.0 ltr he blames the service intervals which is 20k miles or 2 years. He’s recommended if I keep it I should change the oil every 6 months. LR do seem to have got themselves in a pickle ![]() |
Mr Kington Member Since: 06 May 2024 Location: Scotland Posts: 11 ![]() ![]() |
feel for everyone who has had an engine go pop. while I appreciate the numbers overall are probably low, still a nightmare for those affected. At what age did the FFRR start using Ingenium range of engines in the latest L405's ? If these engines are still freely available then at least you have that as an option. |
GraemeS Member Since: 07 Mar 2015 Location: Wagga area Posts: 2770 ![]() ![]() |
The D350 appeared in the MY21.5 L405 but who knows what electrical changes occurred to cater for the engine. |
Meerbusch Member Since: 16 May 2012 Location: Zürich (CH) + Düsseldorf (D) Posts: 327 ![]() ![]() ![]() |
https://www.kleinanzeigen.de/s-anzeige/mot...0-223-4188 L405 SDV8 2017 + Lancia Flavia Coupe 1964 + L322 TDV8 2011 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021 |
northernmonkeyjones Member Since: 24 Mar 2012 Location: derby Posts: 8786 ![]() ![]() ![]() |
There will be a failure rate in most engines. Just the nature of things. Make 200,000 of something and a few will go bang…..
Hello everyone,
