Home > In Car Electronics (L405) > IIDool BT version on MY21.5 L405
GraemeS
Australia
Can anyone advise to what extent my original IIDtool BT version will work on a 21.5 L405?
I expect that I will need a current G4 version for full support to the extent that support is available but in the interim will the BT version do anything assuming that I swap the licence to the L405 from my L322? I should be collecting the L405 in about 1 week.
Post #713163 2nd Mar 2025 12:41pm
looked into this for my 21my and it seems it has to be a G4...
doesnt do much on the CCF side of things though... ... - .- -.
Post #713164 2nd Mar 2025 12:56pm
GraemeS
Australia
Thanks Stan. Their website wasn't very informative but I suppose if my BT can't be used even to read faults then I'll have to get the G4 and wait for ipdates to make it more useful.
Post #713199 2nd Mar 2025 8:29pm
you could try your BT and see if you get anything.... ... - .- -.
Post #713204 2nd Mar 2025 10:02pm
GraemeS
Australia
That's the plan.
Do you have a G4 version?
Post #713209 3rd Mar 2025 2:14am
Unfortunately not, it's a bit to expensive for me. ... - .- -.
Post #713213 3rd Mar 2025 8:46am
Kot
Re: IIDool BT version on MY21.5 L405
According to this post (Thx Stan) they offer an upgrade if you px your old tool. Laughing
https://www.fullfatrr.com/forum/post646376.html#646376 2018 SE SDV8 4.4 Byron Blue
Post #713218 3rd Mar 2025 9:36am
GraemeS
Australia
Thanks Kot. However the Gap Diagnostics website currently only shows an upgrade path from G3 to G4. In time I'll contact Gap.
Post #713231 3rd Mar 2025 10:50am
JW911
How much modification of the CCF can be carried out? All I’m interested in is changing the memory setting so it remembers the previous start/stop setting. 2021 3.0 P400 Vogue
2012 4.4 TDV8 Westminster - gone!
2007 3.6 TDV8 Vogue - gone!
2003 4.4 V8 HSE (LPG) - gone!
2018 F-Pace 25t Portfolio
1974 LR Series III Lightweight FFR
2014 BMW 640i Gran Coupe
Post #713232 3rd Mar 2025 11:34am
on the GAP website you can use a drop down menu which shows you what ecus you can interrogate ..
there doesnt seem a lot of stuff you can adjust, but thats on the listed info..
there is a un-listed info that might adjust the CCF ... ... - .- -.
Post #713238 3rd Mar 2025 12:51pm
GraemeS
Australia
Me too, plus I would like to turn off the auto park brake as my environment is very dusty.
Post #713259 3rd Mar 2025 8:29pm
GraemeS
Australia
I've ordered a G4 to initially be used on my son's Disco4 to calibrate the turbine valve on a replacement engine then swapped to my L405. The G2s that my son and I both have don't have the turbine calibration function which has to be done so that the Disco can be driven without immediate restricted performance.
I switch off start-stop on every start-up but finding the buttons on glass once the vehicle is moving has its risks, so having the G4 will provide a safety improvement. L405 D350 SE Carpathian Grey D5 19" rims
Post #714326 18th Mar 2025 12:32pm
