Home > My Range Rover > New Member & New L322
Sam P
United Kingdom 2007 Range Rover Vogue TDV8 Santorini Black
Hello Everybody
Introducing myself as a new forum member - Sam from Derbyshire. I picked up my third L322 this weekend a 07 3.6 TDV8 Vogue. She appears to have had a pretty pampered life - 115k miles, immaculate interior and very clean arches and sills. A couple of electrical things to sort (obviously!) - passenger heated seat and parking sensors. It even has a Venturecam!!!
Great to be here on this excellent forum.
Sam
Post #709731 20th Jan 2025 3:39pm
welcome Sam to the forum and wiki... Thumbs Up ... - .- -.
Post #709733 20th Jan 2025 3:49pm
toby1
Congratulations. 2012 Vogue TDV8 in Aintree green over sand
Post #709735 20th Jan 2025 4:06pm
mjdronfield
Welcome.
That looks nice and clean.
Previous cars :
2003 Range Rover Vogue TD6
1999 Discovery Td5 ES
1995 BMW M5 3.8 6 speed
1992 BMW M5 3.8
1988 BMW 735i SE
1989 Ford Sierra XR4x4 2.9i
1981 Ford Fiesta Supersport
Post #709739 20th Jan 2025 5:07pm
Sam P
Hi All
I’m in the process of doing some underbody/rear arch rust protection and am considering some work on the upper tailgate also.
Question - is it worth my drilling holes into the bottom of the upper tailgate, to enable me to get some Lanoguard in there? Is this a job that others have done? If so, any advice or pointers would be much appreciated.
Many thanks.
Sam
Post #712120 18th Feb 2025 8:40am
JCW
No need to drill holes, which would probably promote more corrosion in any case, just remove the central number plate light / switch panel (a few torx screws) and you can spray inside the tailgate using a straw type attachment on your spray can / gun.
You may want to use a rust converter first (something like Dinitrol RC900) as there’s a high chance there’s corrosion inside and wait for the products you use to drip out the drain holes each side so you know you have good coverage, A warm day helps here too. Jonathan
2010 L322 5.0 SC Autobiography Black
2007 Defender 90 XS Hardtop
Post #712121 18th Feb 2025 8:51am
Sam P
Great advice. I’ll do that. Many thanks!!!
Post #712122 18th Feb 2025 8:56am
JonnyCJ
United Kingdom 2012 Range Rover Vogue SE 4.4 V8 Sumatra Black
Dynax S50 for cavities and Dynax UC (clear) or UB (brown) for underbody stuff is much better than Lanoguard. You can apply them with 600mm nozzles to get in all those nooks and crannies. S50 in particular is perfect for sills and inside subframe tubes.
Whilst they will both cover and stop rust spreading a good dose of rust converter is always best first as it changes the chemical composition of rust and neutralises it.
Post #713146 2nd Mar 2025 10:02am
pcourtney
I have sprayed Dinitrol RC900 rust converter into my tailgate ( I removed the tailgate lights to access the area ) , I had my lower tailgate open with old rags and towels placed on it to catch the drips coming out of the drain holes
Am about to do a second spray this afternoon, as it is a bit warmer
But a question, before I use the Dinitrol ML Brown cavity wax one evening this week, Thursday looks to be even warmer, surely the cavity wax will block the drain holes - will it not ?
And does anyone know what purpose the drain holes have, I cannot see the point of them, was it just a design error when they made the tailgates, or a carry on from previous models perhaps ?
How does water get in at the top of the tailgate to then drain out of the drain holes ?
Obviously I don't want to block the drain holes if they have a purpose, but then I have read on many forums that people have used cavity wax inside the tailgate after they used some rust converter.
Post #713172 2nd Mar 2025 2:22pm
pcourtney
deleted
Post #713173 2nd Mar 2025 2:22pm
JonnyCJ
Not sure how thick the cavity wax is, but the holes will just be a hole in the metal, so once it’s all set, just poke something up the hole if you think it’s going to be blocked. Doesn’t need too much thought, aside from what you’ve already considered, which is catching the drips !
Post #713174 2nd Mar 2025 2:27pm
pcourtney
I might machine two pieces of wood cut to the drain hole size and poke it in, before I do the cavity wax, I still cannot fathom out the purpose of the drain holes, I mean we are calling them "drain holes" for no apparent reason than that is what they look like to us, but I question the real purpose for them ?
Post #713176 2nd Mar 2025 2:42pm
SeldomSeenKid
Scotland 2008 Range Rover Supercharged 4.2 SC V8 Stornoway Grey
I think they are actually drain holes for when the car was dipped in anti corrosion zinc phosphate solution at the factory. ---------------------------------
2008 L322 Supercharged
2007 Porsche 987 Boxster S
2024 BMW iX3
Post #713193 2nd Mar 2025 7:36pm
pcourtney
good thinking batman - yes that makes sense Smile
Post #713203 2nd Mar 2025 9:31pm
Steveg
United Kingdom 2011 Range Rover Autobiography TDV8 Orkney Grey
It gasses out over the next 1-2 weeks to a thin film, so you should be ok, and as you say they’re not there for drain holes anyway.
Post #713207 2nd Mar 2025 10:51pm
