![]() | Home > Maintenance & Mods (L322) > Removing Rusty 2010 Lower Tailgate Strap Cables |
| JCW Member Since: 13 Apr 2013 Location: Cotswolds Posts: 961
Whatever you do, don’t snap the head of the bolt off as the bolt screws into a blind thread welded on the inside of the panel - been there done that.
| Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1055
I undid mine with my pump pliers they came straight out with a bit of effort |
| Haylands Member Since: 04 Mar 2014 Location: East Yorkshire Posts: 8822
As above, get all that rust off, squirt everyday for a week then I would use the Irwin nut removers in the link below, always had a lot of luck with them, find the size that just doesn't fit over the nut then press as hard as you can inwards while undoing it slowly...
| steve k Member Since: 05 Apr 2024 Location: Berkshire Posts: 64
I agree with JCW's comments. It may also be that the bolt has rusted into the eye boss and the eye boss is rusted to the panel and that s why its become an issue as the bolt head is not strong enough to turn both the bolt and eye? If you have a big hefty stillson type wrench that will grab into the eye that should give extra turning torque to undo the bolt a few degrees at a time. Not sure I've explained this very well! Current: 2003 TD6 HSE
| pcourtney Member Since: 14 Jan 2020 Location: Stansted Posts: 1027
Thank you, ordered, and I have been meaning to do this little job for ages |
| chris_read Member Since: 26 Feb 2012 Location: Louth, Lincolnshire Posts: 479
Mine were so long gone on my last Full Fat that I had no choice but to drill them out, meaning that the thread was also gone. I took the rear light off and did lots of prep on both sides to get rid of the rust then used a washer and a nut on the light fitting side to secure the new tailgate strap.
| yorkshire-dave Member Since: 04 May 2024 Location: Yorkshire Posts: 4
Awesome thanks a lot guys. I won't get time to work on it till the weekend anyway so I'll give it a good spraying with penetrating oil every day in preparation.
