Home > Technical (L405) > vehicle lean when cornering fault
jeffshaw
After having a tyre fitted remove front passenger wheel for a slow puncture I am now getting an amber warning of vehicle lean when cornering. |Switch off and can stay off for 30 miles and then sometimes comes on as red. Feels a bit boaty when driving. Any ideas Cheers
Post #713266 3rd Mar 2025 9:54pm
Sounds like leaking ACE pipes, the car is measuring a drop in line pressure, you will probably have low fluid in the tank and a leak dripping somewhere....
Don't drive it like this, the oil will run out and you will wreck the engine driven pump and need a new one as well as the pipes....
https://www.fullfatrr.com/forum/topic67828.html Pete
Post #713277 4th Mar 2025 9:39am
bigdave
Site Sponsor
United Kingdom 2016 Range Rover Vogue SE SDV8 Corris Grey
Sounds exactly what i had and turned out to be leaking front ACE pipes.
Get onto it asap as Halands says the pump is expensive (£1000) and a devil to fit apparently.
The pipes are also on back order again so id get a wiggle on.
Best of luck.
Dave All things transport - big or small, UK or planetwide.
E-mail info@md-couriers.co.uk
Post #713279 4th Mar 2025 9:50am
TST717
I had similar issue having gone over a small speed bump in Tesco car park ….had to replace the ACE valve block located below the drivers side door area
Same ‘floaty’ feeling compared to how planted it had been previously ..
Post #713382 5th Mar 2025 6:30pm
