![]() | Home > Maintenance & Mods (L322) > RPM fluctuations while driving |
Gsxr1250dave Member Since: 20 Oct 2018 Location: London Posts: 1031 ![]() ![]() |
Yes there is a thread going on at the moment on this very issue
Buie Member Since: 04 Mar 2025 Location: Detroit Posts: 4 ![]() ![]() ![]() |
Thank you for the quick reply. However, my issue was just a slight bit different. My transmission is very smooth and functioning correctly. It's the actual speed of the engine that varies in that slight amount. Initially, I thought it might have something to do with the MAF sensor or air filter, restricting the amount of fuel air mix.
RRPhil Member Since: 22 Aug 2011 Location: Blackburn, Lancashire Posts: 1021 ![]() ![]() |
The torque converter lock-up clutch misbehaving in its controlled slip mode produces exactly that effect. Phil |
Thanks Phil. Looks like I'll take a run a the solenoids first and pray that sorts out the issue. |
dhallworth Member Since: 10 Oct 2011 Location: Glasgow Posts: 3313 ![]() ![]() ![]() |
This is 100% what my car was doing when RRPhil helped me diagnose it. I've done around 6000 miles in it since replacing the solenoids and servicing the gearbox and she's been perfect since! |
Rambles Member Since: 16 Apr 2011 Location: UK Posts: 843 ![]() ![]() |
Out of curiosity
I think you need to ask that of a zf gearbox centre |
