Home > Technical (L405) > L405 Brake line Failure
DrF
United Kingdom 2013 Range Rover SVAutobiography 5.0 SC V8 Orkney Grey
Evening Chaps,
In true RR style, never a dull day, another issue that now needs solving, on the motorway this evening on the way home, the brakes all of a sudden felt very spongy, so I gingerly drove home, not fancying spending hours waiting for the RAC, after 30mins, the red triangle of doom, "low brake fluid". So I coasted home using my best engine braking and coasting through junctions without any braking.
Once home and parked up, upon inspection I find a huge puddle of brake fluid under rear off side wheel. Looks to be leaking at point where pipe connects to brake itself.
So looks like it's going to need to be recovered, looks like connection onto brake itself.
Any help or thoughts appreciated.
I assume a bucket of sand on the block paving to soak up the brake fluid and wash any off paint work quickly., should I wash down wheel and tyre?
DrF
Post #713402 6th Mar 2025 12:09am
Yep, that’s fubar.
Hopefully it Could just be the Flexi hose which has gone, which is a nice cheap fix, probably worth going the pads at the same time in case they were contaminated and giving the disk a good clean with brake cleaner to remove any residue.
If it was me I’d give it all a good wash down, as regards the paving, it will fade eventually, give it. Good scrub with some detergent, but it will have soaked in and will leave a mark.
Hope it’s nothing more serious or into the rigid lines. There is nothing that can't be fixed with a hammer😜😜
Post #713404 6th Mar 2025 12:37am
DrF
Evening northernmonkeyjones,
Thanks for the quick response, I am keeping my fingers crossed its a simple fix. thanks for the advice. Nothing like a quick wash down at midnight.
I dont think its the main lines (at least I hope not!) as there is no fluid under the car and further back towards the front if that makes sense when I jacked the suspension up and traced the lines back, it all seems to be around where the line joins the brake unit itself as was weeping directly at that point when I got home .
The joys hey.....
DrF
Post #713406 6th Mar 2025 12:50am
Gremlin500
Yup new flexy needed, I would do both sides if I were you.
Hard to say if it’s leaking from the swage or the banjo (swage I think, looking again).
These parts aren’t as cheap as you might think.
Bleeding can be a right PITA, if you’re DIY. V6 Vogue - “Less is More” - less to go wrong!
Post #713411 6th Mar 2025 8:34am
What's really annoying is that JLR know the flexis are going to fail....
Never, personally, seen this from any other manufacturer....
Optional service item on 6 year service....!!!
 Pete
Post #713415 6th Mar 2025 10:54am
Kot
Actually for MY18 it’s not optional it is every 6 years! 2018 SE SDV8 4.4 Byron Blue
Post #713424 6th Mar 2025 12:46pm
diesel Dave
England 2019 Range Rover Autobiography SDV8 Santorini Black
Its not uncommon unfortunately as they corrode around the banjo and pipe that runs along the suspension to the body, on the plus side they are easy to do, they come as a kit with two hoses and brake pipe in one. About £70 each ish if memory serves me right. If you DIY it and do both, when bleeding do the N/S first and bleed with the engine running that way you should be ok Thumbs Up
Post #713426 6th Mar 2025 12:56pm
DrF
Thanks for all the responses Chaps,
It's a bit beyond my capabilities, so I am waiting for it to be recovered to Indy, hopefully back on the road soon. Next problem will be parts on back order probably!!
DrF
Post #713435 6th Mar 2025 3:41pm
Meerbusch
Germany 2017 Range Rover Vogue SDV8 Carpathian Grey
Had the same problem at a complete perfect and rust free L405 from 2017 (exept only tank cover), the brake lines are corroded only at the rear axle.
https://www.ebay.de/itm/195873797587?_skw=...R9bz2satZQ L405 SDV8 2017 + Lancia Flavia Coupe 1964 + RRS L494 3.0 SDV6 + C220CDI Convertible 2021
Post #713443 6th Mar 2025 6:08pm
Gremlin500
I did my MY2017 preemptively in 2022 when I upgraded to the big brakes all round, the rears were tatty, the fronts passable but whilst it was all in bits, silly not to do the lot, one less thing to worry about. Covered the metal bits in Lanogard grease, and will continue to do so. Why oh why do LR use all those tinny little STEEL brackets and plain black painted screws? Censored V6 Vogue - “Less is More” - less to go wrong!
Post #713444 6th Mar 2025 6:21pm
JamboM3
Just replaced all 4 of mine, weren't completely gone but would not have lasted another winter.
They are a service item, I believe because they are part uncoated steel! Get some water over the wheel barrel and the brake fluid will eat the paint
Post #713577 8th Mar 2025 4:52pm
DrF
Thanks, I washed everything down straight away with lots of soapy water.
DrF
Post #713579 8th Mar 2025 6:10pm
