![]() | Home > Maintenance & Mods (L405) > Flickering dash ABS, skid, start-stop, speedo while driving |
mpirie Member Since: 26 Jun 2012 Location: In the Highlands Posts: 912 ![]() ![]() ![]() |
I'd suggest starting by checking the earthing points under the front offside wheel arch liner.
mike2013 Member Since: 11 Feb 2013 Location: England Posts: 31 ![]() ![]() ![]() |
Thanks Mike. That's a good idea. That area is a PITA to access though... but will give it a try!
Merchy Member Since: 14 Feb 2021 Location: North Wales Posts: 1238 ![]() ![]() ![]() |
The below you tube video should be handy for you. Also - look in the wiki section, plus a search of posts will reveal a lot more info on this topic.
Mikey Member Since: 10 Jan 2008 Location: Dundee Posts: 1850 ![]() ![]() |
Just in case anyone else has the same issue, I thought I'd circle back here and say it was indeed the ground point mount in the driver's side front wheel arch.
Cam-Tech-Craig Member Since: 04 Aug 2011 Location: Gloucestershire Posts: 16392 ![]() ![]() ![]() |
