Home > Technical (L405) > Tailgate spoiler adjustment.
I have noticed That the corners of my tailgate spoiler we’re rubbing on the C pillar covers.....
So it’s out with the 🔧 and see if I can figure out how to adjust them
It turns out it’s dead easy. much more so than on the 322. Infact LR have built in an adjustment mechanism for us to have a fiddle. Here’s How.
Pull out the retaining plug in the hinge cover.
Remove the hinge cover.
Using a 13mm socket slacken off the 13mm retaining nuts. But don’t remove them. There is no need, just wind them out a few turns to the end of the bolt.
Using an E7 reverse torx socket wind the inner bolt either in or out depending on whether you want to raise or lower the spoiler.
Close lid and check and redo a bit more if needed.
Tighten everything up and put it back together. There is nothing that can't be fixed with a hammer😜😜
Post #565966 31st Aug 2020 12:59pm
thanks Mark.... Thumbs Up
theres also a great powerfuuk video that shows this process ... - .- -.
Post #565968 31st Aug 2020 1:02pm
That would have been useful.....😂
Took about 10 mins was about to take it off then spotted the ends of the bolts were splines. There is nothing that can't be fixed with a hammer😜😜
Post #565969 31st Aug 2020 1:06pm
adara
Romania 2019 Range Rover Vogue 2.0 PHEV Santorini Black
Had to do this in mine too.. At the time I used the powerfuluk video:
Post #566031 1st Sep 2020 6:26am
Dave G
United Kingdom 2013 Range Rover Autobiography SDV8 Indus Silver
Great thread, thanks Very Happy
Re-aligned mine this afternoon, then spent hours polishing out the scratches on the C trim Neutral
Dave.
Post #566124 2nd Sep 2020 5:53pm
elsterracer
Germany 2018 Range Rover Vogue SDV8 Corris Grey
Re: Tailgate spoiler adjustment.
It turns out it’s dead easy. ...
Thanks northernmonkeyjones !!!
Now I know more than my official RR garage.
...already hate thinking about the polishing work.
How nice to have this forum! How stupid to need a forum for a car of that value...
Post #651941 29th Dec 2022 4:00pm
luxmoggy
Germany 2019 Range Rover Autobiography SDV8 Montalcino Red
Hello
So, I tried to do this today. I didn't manage to get it right. When I do the nut up, It seems to go back to the original level. No matter what, I seem to do the inner screw.
Advice? SDV8 AB MY 2020
MINI Cooper S Cabrio
Kit: Jaguar XK140 (in progress - the website is link to build)
Post #713641 9th Mar 2025 4:00pm
Gremlin500
@Luxmoggy:
These 2 pics might help how to move the “hole in a hole” DOWN, to get the tailgate further UP:
(Left, then Right) I messed around for ages, eventually needed a helper to stop it moving back as I re-tightened the bolts.
 V6 Vogue - “Less is More” - less to go wrong!
Post #713649 9th Mar 2025 6:49pm
andygts
You'll probably notice if you look closer the spoiler is fine..... It's the whole tailgate that has dropped.
Plenty of vids on how to adjust. Current
2017 Range Rover Sport SVR
2001 Porsche 911 Turbo
_____________________________________
Previous
2007 Range Rover Vogue SE TDV8
2002 Range Rover HSE TD6
+ Many other non LR products
Post #713688 10th Mar 2025 10:43am
luxmoggy
thanks. I hopefully have time this weekend to check SDV8 AB MY 2020
Post #713721 10th Mar 2025 7:44pm
Gremlin500
Exactly! that was my issue, hence mentioning the hole positions. The plastic spoiler is light, and doesn’t normally get out of position, but the tailgate is heavy, and drops over time, it’s very common on the L405. V6 Vogue - “Less is More” - less to go wrong!
Post #713727 10th Mar 2025 8:55pm
I wouldn't necessarily agree with you gremlin... I adjusted my SVA's boot lid when I first bought it and its stayed perfect now for 3yrs + Whistle Thumbs Up
Post #713749 11th Mar 2025 1:40am
Gremlin500
@CTC:
Yes, I also adjusted mine 3 years ago and it too is still fine, perhaps they were delivered that way?
It seems commonly reported here and elsewhere, maybe the bolts were under tightened on the assembly line, or they just got it wrong? V6 Vogue - “Less is More” - less to go wrong!
Post #713755 11th Mar 2025 7:53am
5 year check and it’s still ok.👌
Can’t believe I’ve had this car 5 years. I think that’s probably getting on for the longest tenure. There is nothing that can't be fixed with a hammer😜😜
Post #713757 11th Mar 2025 8:22am
andygts
I'm pretty sure they just didn't torque the nuts up tight enough at build, it's common accross at least 3 land rover platforms that ive had
My old L405 was bad when i got it...it was my first job to adjust it and it lasted the 5 years I had it.
The Mrs Evoque I have noticed getting worse over the last 4 years but not causing any issues or touching where it shouldn't so not touched it.
My SVR is out slightly but I think someones also bodged it and adjusted the spoiler to make it less noticeable. Current
Previous
Post #713792 11th Mar 2025 1:22pm
